What version is my Outzone pcb?
aerobert
Sweden
As pictured, the intro shows the guy in the door of the drop ship and the text says "mission are you ready? Destroy all of them. Goodluck!!"
There was a good site that describes the differences between the romsets based on this informaiton but I cant find it.
I also have the version with the different intro than the japanese one, so wondering the same :)
I found the following:
-version 1.0/prototype plays music in a different order than the OST (perhaps some music is even missing); ex. the stage 6 theme plays in stage 2
-version 1.1 has the correct order, the game-start message is different, and the other changes mentioned above
-version 1.2 appears identical to 1.1 but harder, this could even be some crazy hack but the MAME team sure seems to think it isn't so I'm just calling it 1.2 anyway
the version you need to sell to me...
lol for any particular reason? I see plenty Outzone for sale. :)
From what I understand the "hard" version starts with second loop settings.
Yes you can easily see that depending on if the first enemies shoot at you or not at stage 1 apparently
Yeah the first cyborg fires in an instant. However I don't know if that's on standard difficulty setting (the pcb is packed away at this time).
I'm really trying to find this webpage I'm talking about. It went into detail exactly about the differences and how you could identify it without dumping the roms. I stumbled upon it through links but never found it via search engine.
Then you most likely have the harder version if shmups forum is correct
If I remember correctly from the page mentioned above, dip setting easy is the same as normal on the "regular" rom.
I think another Swedish person had the harder version, and difficulty settings did nothing so he had to swap the rom for the easier version. Got help from another Swedish person to do that.
The factory conversions can be seen easily by if you have a daughter board or not on the pcb I learned.
And you cannot swap rom for the easier version on those to my understanding.
Further contact with Guts reveals that there was a lengthy discussion about the versions in the french shmup forum here: http://forum.shmup.com/viewtopic.php?p=562195
One of the posts suggest that set 1 (outzoneh.zip) isn't simply like the second loop of Set2.
TRANSLATED
"But the Set 1, ouh lala ...... you want a challenge? Play on this one, it's simply HARD mode.
From the start the enemies shoot you directly but be careful, not like in the 2nd Loop of Set 2 and the others, no no no, a little faster and they are also a little more resistant. And then the red bonus enemies are less frequent as well.
TRANSLATED
Yeah that's what I heard, and that dip switch settings in terms of difficulty does nothing. Hence people wanting to rom swap to the easier version if they get the harder one
And to add to this misery it seems there are differences between the region versions (which is controlled by jumpers) as well. The french forum mentions the default extend settings are different. Then who knows what else has been changed between regions.
So in that case we have rom+region differences, that’s a lot of combinations.
Have always wanted to know which one I had? It may be the Korean version due to the Korean chips on mine?
And no I didn’t cover up the words above “Made In Japan”. But I am trying to remove it and it seems sooo dam hard to wipe off.
