Can someone identify a connector for a board for me?
HornheaDD
Texas
Apologies, Im sure this is idenitifyable, but I tried searching using the info on the board itself and came up with bupkis.
I have a Brook UFB that connects to a JAMMA edge connector to put into my arcade cab. The connector you see here allows the 20 pin cable from the UFB to connect to this little PCB. It came without a Player 2 in it. I'm searching for either the pins to go in here, or that connector you see on the left side, but I'm not sure what to search for.
I tried 20 pin connector but the result I got doesn't look like this at all.
Looks like a IDC connector. Similar to the cables for the Darksoft Multis?
Yeah, I'd say the same. The magic search phrase I use for those is "IDC shrouded box header", just make sure it's 2.54mm/0.1" pitch and the right number of pins.
and the female one? somone have the part number?
Lots of manufacturers make these. I'd search for "IDC connector for cable mount" or "IDC connector for ribbon cable" and then go from there. You'll need a crimp tool to fit them nicely, alternatively two blocks of wood and a mallet does also work ;)
