SOLD CBox Supergun (2019 version)
shine
NorCal
$120 shipped to the US
For sale a neat CBox supergun.
It does have USB encoders integrated - similar to Undamned, same latency (tested against a pair of undamned I had in another supergun). Buttons can be configured via the same method, press 3 buttons when connecting then map (but not saved after shutting down). Order is shuffled, but I will give easy instructions on how to easily map.
It also has DB15 connectors (for Neogeo sticks), RGBS output + YCRCB + RCA, 456 for kick harness, voltage tweaker, and a nice metacrilate case.
It works great and has an amazing image quality through RGB (can include SCART cable for $15 more). I am selling because player 2 USB encoder has lost signal for button 6 and can't Street Fighter with it anymore. DB15 will be able to use all 6 buttons, it's just the P2 USB encoder (it seems chip is fault, some days ago it was fine, tracks are ok). 12V PSU included.
Arrived today!
Works as it should….
-How do you button remap &
-Do you have a link from where you got it?
Thanks
Arrived today!
Thanks
Hi! glad to hear.
For USB mapping: keep pressed 3 buttons when connecting the controller, if done right, it will start blinking. Release the buttons then press the buttons in this sequence 345 126 (they got the order wrong on the tracks).
This is the the link (not sure if same store, but model looks the same)
https://www.aliexpress.us/item/3256801083990851.html?spm=a2g0o.detail.0.0.e280oGwJoGwJzF&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40050.362094.0&scm_id=1007.40050.362094.0&scm-url=1007.40050.362094.0&pvid=cfb320b8-c47d-4b91-9958-a75889fa1b34&_t=gps-id:pcDetailTopMoreOtherSeller,scm-url:1007.40050.362094.0,pvid:cfb320b8-c47d-4b91-9958-a75889fa1b34,tpp_buckets:668#2846#8113#1998&pdp_npi=4@dis!USD!158.12!134.4!!!158.12!!@2101e9ec17029436413626209e088b!12000015534011765!rec!US!739964440!
