FS Cewlix here
kcarcadegame
rosemead CA
2 left
These come complete with monitor, sticks, buttons, and I'm guessing wired for jamma? Local pickup
Bro, I want a vewlix so bad. The guy that was gonna do it locally for me, his communication sucked and has yet to reply to my last set of questions as I had some concerns. So it's either this, a real vewlix, or a kraylix clone
I say real Vewlix is worth the difference in price, but Cewlix is nicer than Kraylix for sure.
One major point to keep in mind... Its a LCD based cab, so to display JAMMA you'll need a scaler/scanline doubler of some kind.
Not all scalers are created equally, in fact only 3 IMO are worth owning.
  1. OSSC
  2. xRGB Mini (Framemeister)
  3. Official Taito JAMMA Kit (Taito Scaler)
I think the kraylix is really nice. It's built incredibly well. But I think it may come down to wanting sheet metal/plastic vs wood
Oh nice, I didn't know Taito made an official scaler. Are those of high quality? I have an OSCC, so I am not worried.
OSSC is king, followed by the xRGB Mini.
The Taito scaler is awesome for what it is, but the support is very very limited (only popular boards will sync with it).
Kraylix looks nice, but that wooden body makes it very heavy.
I would say avoid and get Chewlix if the price of a real Vewlix is too high.
Yeah I haven't had any luck with a real vewlix at a cost I can afford, especially with a 2p panel. Granted, gaining a fast i/o would be nice to have.
Do these cabs allow monitor rotation to vertical? I wonder how easy it is to replace the monitor with a higher quality one. I'm pretty sure these will be a little too laggy for my tastes. If swapping monitors isn't too much of a hassle, I may be sold
In the official a monitor can be mounted either way, but you must totally disassemble the side panels and remove the speakers.
This is one of @Derick2k 's Capcom cabs when we replaced the LCD...
As for easily swapping with another LCD, that's a negative far as I can tell.
No I haven't de-cased every commercially available LCD to test this theory...
I'm just saying because the LCD isn't mounted directly to the cab, rather it gos inside its own protective bezel/case.
This is the back-side of the stock Capcom LCD (the Sanwa) for reference...
FastIO's inside Vewlix cabs are rare, I'd say if you are buying anything other than a Diamond you have zero chance of finding one.
Even inside the Diamonds they aren't common, mine came with one but thats because it was configured as a NesicaLive cab (marque was visible in purchase shot).
This is NOT how Vewlix cabs are sold from Taito...
The only way you'll find one with a 2p panel installed is IF the original operator ordered one and replaced it himself before selling it to you.
They never play two on a single cab in Japan, check out some pics from our adventure...
They're not heavy, I don't have my Vewlix yet for comparison but my Kraylix is lighter than any of my other machines by a large margin. empty and with the control panel removed I can pick it up with one hand. I know because I have.
With that said I regret putting money into this thing instead of just holding out for a decent price on a Vewlix.
I'd drop $2K on a Chewlix before I bought another Kraylix.
Could you explain reasons as to why you would choose a chewlix over a Kraylix? Maybe some pro's and cons of both, if you do not mind sir.
That could be a bummer. I'm curious if anyone has ran input lag tests on these chewlix monitors. As that is a worry of mine.
Here's my experience:
I wanted a Vewlix a few years back... at the time they were selling around ~$3K+ shipping for an F. came across a Kraylix V3 on eBay that was local to me, bought it from the guy in an offline deal. Basically the the empty wood cab+ control panel and header plexi it was assembled and pre-painted by the guy who makes them in TX (so automotive grade paint, pinstriping etc). The guy who was selling it had the Panasonic (I think) LCD that the V3s were designed for and had gutted a Madcats Xbox 360 stick to populated the Player 1 control panel and was basically using it like that. with an Xbox 360 inside. no P2 controls, no speakers (he was using the TV's speakers) and no front coin door. I bought it without the TV because I wanted to go with the Samsung U3000 that the Kraylix V4s were being designed for (That's the biggest difference between the V3s and V4s) since they were lower lag than the Panasonic.
I bought my Samsung U3000 and designed/build my own mount for it. The V3 cabs if you don't know "mount" the TV by having a pocket on the left and right sides that the edges of the screen slides into, then there are 4 large carriage bolts in the back where the heads press up against the back of the screen to hold it in place by pressure. So basically you're intentionally putting a bending force across the screen to hold it... like this:
The Samsung has a much smaller bezel around the screen so I couldn't use this "mount" even if I wanted to because the screen wasn't wide enough to fit into the pockets on the sides. So I designed a wood bracket and screwed that into the back board on the cab (I say back board because there is no cab back behind the monitor, just a single horizontal piece of wood, that's partly why it's so light) and then I put holes in that bracket so that I could mount my Samsung using the proper VESA mount points.I got the spacing perfect so it's completely flush mounted; It looks pretty good, and most people dont' realize it's a normal TV until I point out the Samsung logo on the lower bezel.
I installed some Rockford Fosgate automotive speakers. there are no screw holes for the speakers so I was on my own to make sure they were mounted evenly and not rotated. I used a LeiPai stereo amp to power them. I also installed a Happ coin door (just a blank one) in the front and bought and installed my own service panel on that for power and reset switches. I also used the AC Power panel from a Sega cab that I bought so it had proper power connectors and a switch/fuse on the back.
I was planning on using this as a MAME cab so internally I used a Ultimarc I-PAC for the controls and it has a PC mounted inside. BTW There's nothing inside to mount to, you just have the floor and the walls, thats it. So I cut a piece of MDF that fit across the bottom and mounted my PC guts to that... I had to mount the PC guts to that because the internal space is so small that the PC case (a pretty standard mid-tower, about the size of a Taito X2) wouldn't fit, so I had to decase it, and even as it is now the GPU with the DVI plug in it barely clears between the kick panel and the back door. I wanted to mount a sub-woofer inside but unless I built a custom fit enclosure for it there really isn't enough space. Here's a picture of when I was mocking up the parts on my mounting panel:
I used a micro-ATX Mobo too, you can see that huge black box in the center is just a standard sized PSU... the space inside the cab is TIGHT.
Not including the PC stuff I probably spent about $600 on parts to make this a cab "complete" and even now there are still some things that are incomplete about it compared to a real cab.
Here's what my cab looks like:
My list of gripes with this thing
1. If you have any interest in swapping PCBs at all, do not buy this cab. the front door is tiny and you really wont be able to fit anything through it. it works for accessing my service panel and volume knob but most PCBs wont fit through the door, you'll have to put them in through the back door.
2. as I mentioned above there's almost no space inside for anything, you probably wont fit an X2 in there unless you put on an an angle or something, same goes for most larger PCBs, and there's nothing to mount any of them too either.
3. The cab isn't really a cab it's just a box that looks like a cab. If you want to sit down and play games on a mounted joystick then great, but if you want a cab with all the things that make it a cab (like AC power wiring, a service panel, JAMMA or JVS harness, etc. then you're building all that shit yourself.
4. The control panel design is kinda bad. There's no below panel access, you have to pull the whole panel out to work on it and the buttons/sticks mount in pockets cut into the MDF. And because of the way the panel is designed you can't use carriage bolts like a normal panel they screw in from the top. The sticks are placed a lot wider than a real Vewlix so as a result the palm of your left hand on the P1 side sits right on the bolt and because it's not a carriage bolt (they come with DECK SCREWS) the slot on the top of the screw digs into your palm. I've debated counter sinking the holes and swapping to countersunk screws but I honestly don't play the cab enough these days to put in the effort.
5. the control panel box mounts with 2 latches and doesn't even have anything else to hold it in place. So if you push and pull on the panel you can move it around and make it crooked to the cab, I cringe whenever I have to pull the cab out from the wall to get at the PC because the only place to grab it is the control panel and I know 100% of the cabs weight is being put laterally on those latches.
6. at the end of the day it's an MDF cab and it it looks and feels like an MDF cab. it looks great in photos and from about 10ft away the uninitiated wouldn't be able to tell the difference between this an a Vewlix unless they were side by side but up close you can see the "softness" and unevenness of the edges. you can put your finger nail into it and dent it through the paint, and there's nothing on the bottom the cab just sits on teh floor, no feet or anything. my basement partially flooded a couple of years ago only a really thin layer of water, as if someone spilled a couple of gallon jugs. All of my console games and electronics were fine because they were all on shelves, all of my real arcade machines were fine because even the wood cabs have feet that keep the bottoms off the ground... the kraylix though. that MDF sucked that water up like a sponge, it took me weeks to get it dry and I had to design some custom clamps to keep it from swelling, and the paint still cracked in a few spots on the bottom because of it.
At the end of the day, if you want a cheap cab to keep a console in, or if you want to build a MAME cab and not feel bad about drilling holes for extra buttons and other customizations then it's a great option for that. But if you want a REAL arcade machine that you can use with REAL arcade boards then it's not worth the hassle because after you drop all the time and effort to make it work with actual arcade boards you will have spent just as much money as you would have just buying a Chewlix or a Vewlix and you'll still be dealing with all the little headaches and design flaws that come along with the Kraylix.
Wow man, You really went in! I really appreciate your feedback. I think you really set it in stone for me. Every point you made really made sense. Some of the things you really pointed out, I really had concerns about, and nothing on the internet really showed how to access it, and that was the control panel. I love how on the Vewlix and Chewlix, that it is opened from the top, and you can place a lot of custom components in there, or even spare parts. I knew the Kraylix wouldn't be able to do that, but I wondered how the CP handled all together.
I personally liked the idea that the Kraylix CP controls are spread further apart, for more room between both players, But again, I did have concerns of that screw holding down the plexi.
I do plan on using arcade boards. I plan to use consoles and or a small form factor PC(or just use a modded console for emulation), so knowing that the Clone is much better suited for doing swaps, is a big deal!
And I definitely prefer sheet metal/plastic over the wood, for sure!
I really appreciate the detailed response, brother!
if you were located in europe i would snap one up , ive been googling for 3 weeks trying to source a chelix/viewlix , guys how much do viewlix's cost from taito direct? abd where can i find there contact info?
