Chassis power wires (black) to cabinet wiring (black, white, green)
Galdaien
Iowa
Hello I have a Hantarex mtc9110 that I’m trying to put into a SF2 setup. The power wires from the isolation transformer in the cabinet are black, white and green but the power wires from the Hantarex chassis are both black. Hopefully the pic explains it better… Just curious how I should be wiring this? Thank you!
Ideally you would check these with a multimeter, but more than likely
Black is live
White is neutral
Green is Earth ground
On the chassis, the live wire is the one that is connected to the fuse.
Earth ground you connect to the chassis with a fork terminal under a screw. There are screw holes in the metal bracket that is along the edge of the chassis.
I sure hope the sf2 1up can hold that heavy monitor, better to add a bunch of supports.
(I opted for a PC with some nice GLSL settings to imitate a curved monitor w/ scanlines & bloom etc..)
Edit: Never mind, that looks like a real cab, i didn't pay attention lol.
