WTB Compact Flash Extender
Want To Buy
theoddtech
Los Angeles
Trying to make progress on some Lindbergh stuff again after needing to take a break from some projects, seems like a good way to get access to the cf card as is - basically looking to do the standard external power, let the Lindbergh unlock the CF, then attach to a pc for modifications/access.
Unless I'm mistaken the PCB is connected by a 40-pin ribbon cable right?
Why not just use an ATA extension to reposition the pcb elsewhere?
?( on a Lindbergh the CF card port is soldered directly to the motherboard.
A quick search doesn't turn up much other than this: https://en.esskabel.de/adapter/datasheet/ada-compactflash-extender-0430ffc
There are also a few options here: http://www.sycard.com/product.html#compactflash
The 182 looks like the most suitable out of all of them
My mistake, maybe I had seen a different pcb when I was looking a while back- I thought the system used the same type of CF GDROM replacements.
yeah, looks like a lot of options out there... https://en.esskabel.de/adapter/datasheet/ada-compactflash-extender-0430fpc-dma
but pricing is going to be pretty high because the products are designed for industrial testing and development more than actual end-users...
This is the one I used.
