Final Fight Board Issue
Beatrush
Canada
Hello,
I recently bought a Final Fight board from a local custom arcade cabinet shop in my city. When I bought it from their online store, it didnt mention there was a problem with the board so when I received it, I was pretty annoyed to see it had a tag that said "no picture".
I booted the board up using my small cab and all that shows up is a yellow screen. There is no sound as well coming from the board.
To make sure it wasnt the jamma extension cable or the small cab, I tested them on a few different boards and there was no issues
I'm still relatively new to arcade board collecting so I was wondering based on the board and the screen, is this something fixable or should I demand my money back from the shop?
https://www.dropbox.com/s/8lrkx6kij8lr2uj/Photo 2019-03-22, 11 18 53 PM.jpg?dl=0
https://www.dropbox.com/s/c2p97oxvo6g6590/Photo 2019-03-22, 11 19 04 PM.jpg?dl=0
If anyone can shed some light on this, that would be greatly appreciated. Thanks
Try reseating everything. As in, A board to B board, B board to C board, and all socketed chips. Then check +5V. CPS1 is picky with 5 volts.
Other than that, check the customs and other surface mount chips. Gently apply pressure on the accessible ones and see if anything changes on screen. If so, could be a loose solder joint.
Hi,
The fact that the fault was undisclosed is very misleading. I'd be contacting them for a refund ASAP.
I contacted the seller to see what we can do. I buy from these guys frequently so this is the first time I had a bad experience with them.
Thanks for the tip, I'll give it a try this weekend and see what happens.
Tried reseatting everything and no dice. Also pressed down on the chips and nothing as well.
I emailed the company to request a refund.
If I am stuck with the board, would it be possible to move the B and C boards to another A board? Im looking into picking up Area 88 or US Navy and was wondering if I could move the final fight B+C board onto their A board.
