Instilling Different drivers on Niko Multi
Tonybolony
Leeds , UK
Has anybody been able to do this, i can get it to install a new GPU but when it reboots it still puts up a ? by the pieve of hardware as if it doesnt keep the information ?
There is a write filter enabled, so on each reboot the writes are undone.
I'm not sure how it's disabled, probably a service you'll need to disable. but @Niko might be able to explain it better.
Some info here: https://www.arcade-projects.com/threads/type-x2-pc-build.3481/post-47393
Disable EWF - reboot - check if disabled? Yes-> install card + drivers - reboot - check if OK. - enable EWF -> reboot -> Check if EWF still disabled. i'd guess.
