Is my Naomi Cart Missing Bios?
DJLC
Saint Louis, Missouri
I have a Akatsuki Blitzkampf cart that doesn't work (Error 1 on the boot up) and I've got JP bios and the sockets look clean. I can boot anything else on it so I believe it should be good, and the issue is with the cart.
I opened up the card and I noticed a missing chip. I'm not familiar with the newer post gd rom Naomi games so am I missing a chip on my cart?
According to the MAME driver there is no chip at that location for this title on that naomi cart PCB ver, so that's normal.
What version JP bios? Latest H / Multi?
Code:
NFS Flash ROM board
171-8346C (C) Sega 2005
|  IC12          IC8                    ----CN2----       -|
|             (IC22,1-7)                    IC7            |
|                          IC6                             |
|  IC13          IC9                              IC4      |
|             (IC8-15)                                     |
|                            IC5            IC2      IC3   | male side
|  IC14          IC10             JP1             IC16     |
|             (IC16-21)           JP2                      |
|                                           IC1            |
|  IC15          IC11                                      |
|        ----CN3----                    ----CN1----        |
Notes:
      The female side of the cart PCB only has traces
      IC1   - 74LVCH16245A (16bit transceiver with direction pin)
      IC2   - XC3S50 Xilinx Spartan FPGA (TQFP144)
      IC3   - PIC16C621A EPROM-Based 8-Bit CMOS Microcontroller (PDIP18) with internal memory
              On the end of the number, -JPN means it requires Japanese BIOS, -COM will run with any BIOS
      IC4   - XCF01SVG Xilinx Platform Flash In-System Programmable Configuration PROMS (TSSOP20)
      IC5   - 74LVC08A (Quad 2-input AND gate)
      IC6   - 74LVCH16245A (16bit transceiver with direction pin)
      IC7   - socket for EPROM (DIP42), either 27C160 or 27C322
  IC8-IC15  - S29GL512N FlashROM (TSOP56), 512Mb. Not all positions are populated
      IC16  - R3112N431A Low voltage detector with output delay (SOT-23-5)
      JP1   - JUMPER ROM board Bank: 1-2 = Master, 2-3 = Slave
      JP2   - JUMPER IC7 EPROM: 1-2 = Enabled, 2-3 = Disabled
   CN1/2/3  - connectors joining to main board
      CN4   - 6 legs connector for ISP programming
   Games known to use this PCB include....
                                                    Sticker      EPROM        FLASHROMs   XC3S50   PIC16C621A    XCF01S
Game                                                on cart      IC7#         # of SOP56  IC2#     IC3#          IC4#     Notes
Akatsuki Blitzkampf Ausf. Achse                     841-0058C    not present  4 (512Mb)   present  317-5130-JPN  present  IC2# is labeled "VER.2" - IC4# is marked "5A" - IC#10 & IC#11 are empty
Asian Dynamite / Dynamite Deka EX                   840-0175C    not present  4 (512Mb)   present  317-0495-COM  present  IC2# is labeled "VER.2"
Asian Dynamite / Dynamite Deka EX (older)           840-0175C    not present  4 (512Mb)   present  317-0495-COM  present  2x PCBs dumped, 840-0175B and 840-0168B, contents is the same.
Illvelo (Illmatic Envelope)                         841-0059C    not present  4 (512Mb)   present  317-5131-JPN  present  IC2# is labeled "VER.2" - IC#11 is empty
Mamoru-kun wa Norowarete Shimatta                   841-0060C    not present  4 (512Mb)   present  317-5132-JPN  present  IC2# is labeled "VER.2"
Manic Panic Ghost! (USA)                            840-0170C-01 not present  5 (512Mb)   present  317-0461-COM  present  requires 837-14672 sensor board (SH4 based) - PCB s/n is 840-0170B-01
Melty Blood Actress Again (Japan)                   841-0061C    not present  6 (512Mb)   present  317-5133-JPN  present  IC2# is labeled "REV.A" - IC4# is marked "5A"
Melty Blood Actress Again Version A (Rev A)         841-0061C    24455        6 (512Mb)   present  317-5133-JPN  present  IC2# is labeled "REV.A" - IC4# is marked "5A"
/MushiKing The King of Beetles
\(2K3 2ND Ver. 1.000-, China)                       840-0157C    not present  1 (512Mb)   present  317-0437-COM  present  requires 610-0669 barcode reader, 838-14245-92 "MAPLE/232C CONVERT BD" (MIE-based), 838-14243 "RFID CHIP R/W BD" and RFID chip
/Mushiking The King Of Beetles
\Mushiking II / III / III+ (Ver. 1.001) (World)     840-0164C    not present  2 (512Mb)   present  317-0437-COM  present  requires 610-0669 barcode reader, 838-14245-92 "MAPLE/232C CONVERT BD" (MIE-based), 838-14243 "RFID CHIP R/W BD" and RFID chip
\Mushiking II / III / III+ (Ver. 2.001) (World)     840-0164C    24357        2 (512Mb)   present  317-0437-COM  present  IC4# is marked "18"
\Mushiking II / III / III+ (Ver. 1.000-) (Korea)    840-0168C    not present  2 (512Mb)   present  317-0437-COM  present  requires 610-0669 barcode reader, 838-14245-92 "MAPLE/232C CONVERT BD" (MIE-based), 838-14243 "RFID CHIP R/W BD" and RFID chip
\Mushiking IV / V / VI (World)                      840-0180C    not present  2 (512Mb)   present  317-0437-COM  present  IC2# is labeled "VER.1", IC4# is marked "8A", requires 610-0669 barcode reader, 838-14245-92 "MAPLE/232C CONVERT BD" (MIE-based), 838-14243 "RFID CHIP R/W BD" and RFID chip
Mushiking The King Of Beetles 2006 First (Japan)    840-0167C    not present  2 (512Mb)   present  317-0444-JPN  present  IC4# is marked "18", require 610-0669 barcode reader
Mushiking The King Of Beetles 2006 Second (Japan)   840-0171C    not present  2 (512Mb)   present  317-0444-JPN  present  IC4# is marked "18", require 610-0669 barcode reader
Pokasuka Ghost!                                     840-0170C    not present  5 (512Mb)   present  317-0461-COM  present  requires 837-14672 sensor board (SH4 based)
Radirgy Noa                                         841-0062C    not present  4 (512Mb)   present  317-5138-JPN  present  IC2# is labeled "VER.2" - IC4# is marked "8A"
Rhythm Tengoku                                      840-0177C    not present  4 (512Mb)   present  317-0503-JPN  present  IC2# is labeled "VER.2" - IC4# is marked "8A"
Driving Simulator                                   840-0178C    not present  8 (512Mb)   present  317-0502-JPN  present  IC2# is labeled "VER.2" - IC4# is marked "8A", require 3 comm.bd. linked Naomi 2
Star Horse Progress Returns (main screen left)      840-0183C    24480        4 (512Mb)   present  not present   present  IC2# is labeled "VER.2", requires 837-13785 ARCNET&IO BD
Star Horse Progress Returns (main screen right)     840-0184C    not present  2 (512Mb)   present  not present   present  IC2# is labeled "VER.2", requires 837-13785 ARCNET&IO BD
Star Horse Progress Returns (live and voice)        840-0185C    not present  4 (512Mb)   present  not present   present  IC2# is labeled "VER.2", requires 837-13785 ARCNET&IO BD
Star Horse Progress Returns (satellite)             840-0186C    not present  2 (512Mb)   present  not present   present  IC2# is labeled "VER.2", requires 837-13785 ARCNET&IO BD
Star Horse Progress Returns (sound)                 840-0187C    24481        4 (512Mb)   present  not present   present  IC2# is labeled "VER.2", requires 837-13785 ARCNET&IO BD
Shooting Love 2007                                  841-0057C    not present  4 (512Mb)   present  317-5129-JPN  present  IC2# is labeled "VER.2"
Touch De Zunou (Rev A)                              840-0166C    not present  2 (512Mb)   present  317-0435-JPN  present  IC4# is marked "18", requires 837-14672 sensor board (SH4 based)
  • Like
Reactions: nem
