Issue with Fatal Fury Special MVS cart not booting
Evan
USA
Hello. I have a fatal fury special cart that refuses to boot up properly. I ran a crc check in Unibios which checked out fine. It racers the neo Geo intro then crashes with an error. Photos attached. Also the motherboard I’m running it on.
T
can you provide a picture of the crash screen
That picture with the green screen is the crash screen. If I do nothing the cart just resets the neo Geo intro forever.
T
The picture with the green screen is the memory viewer, not the crash screen.
I also found your crash picture on neo-geo.com. Different crash locations on both. With the cart having the correct crc values I would suspect it could be a ram issue. You might try turning on all hard dips and power it up. That should do the stock/unibios basic ram test. If that doesn't find anything I would try the diag bios.
That’s just so odd as no other games have any issues. I’ll look into it though.
I tried the diag bios and it says all tests past. At a loss what the issue could be.
