jamma/jvs arcade connect to ps3/4/5/xbox360/Nintendo Switch/PC
china
Now, it has been updated, adding a raspberry pie pico chip, so that it can support PlayStation 3, PlayStation4, PlayStation5(Must be a PlayStation5 game that supports PlayStation4 controller.), Nintendo switch, xbox360, keyboard and connect PC computer. Transfer to jamma and JVS consoles.
which store sells this? I cant find it on the sq arcade store
Just found this amazing item on AliExpress. | Arcade JAMMA JVS to PC/PS4/PS5/Xbox360/NSwitch LCD Cabinet Pico MiSTer Fpga CRT Emudriver 2-in-1 Conversion Board Xinput Dinput
https://a.aliexpress.com/_ExSUM5j
https://www.aliexpress.us/item/3256806144998981.html
Thanks for the link!
Do you have a manual for the product?
If not:
1.which USB Mode supports all the consoles?
2.do you connect micro usb cables to the RPIs or how are you supposed to connect the pcb to the consoles?
3. regarding point 8 of the description: what do you mean by „Holding B1-B5“? Which button? I dont see buttons on the RPIs.
4. again point 8: „select 5 operation modes“ - which 5 modes? You only list 3 USB modes
If not:
你好:
1.raspberry pico usb support all consoles
2.use USB micro cable raspberry pico.
3.B1-B5 is jamma buttons 1-5.
4.board have three usb port. 树莓派以外的那个USB端口支持额外的三种模式。
Thanks for the explanation. What are the 5 modes you are able to select through the jamma buttons?
Thank you for making this product. And it also supports PS5 controllers. How do can you get buttons 5 and 6 to work? Do you sell a kick harness for this converter?
What link should I use to purchase this adapter and kick harness?
can I connect the kick harness of my controller panel to this connector of Jamma to PC by SQ Arcade?
My candy cab already has the kick harness. Can I connect it to the Jamma to PC?
Hello @SQArcade,
Are you saying that my candy cab’s kick harness will connect to the sq arcade pc to Jamma adapter but you can’t guarantee that it will work? Can’t I setup the buttons on the computer later on?
