Latest king of air pcb (640x480?)
Mrshplooga
Toronto
Hey guys
I've recently picked up a king of air pcb and when I run it in my cab via vga, I get a scrambled up image, I dont remember the model number of the monitor but at one point I was running mame at 640x480 so I know it supports it. If needed I can get the model number of the monitor, another side note I have also ran a vga cable from the pcb to my sega universal/Naomi setup and get the same result. I would like to run the pcb but was under the impression it ran at 640x480, is it running at another unsupported resolution?
Apparently these can output also 15khz and 800x640 in addition to regular VGA. Do you have an LCD you could plug it in to? You could at least rule out the 800 x 640 if it doesn't work on that either.
Just an update i plugged the pcb into an lcd and it picked up another resolution, Monitor didn't mention which though. is this the case with prior versions aswell? really would like to get this running as my monitor only supports higher resolutions ie 640x480
