JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Dissapointed to learn mach breakers dousnt use regular jamma for all players but the special connector
Does anyone have the pinout? My google-fu comes up short
My assumption would be it will be the same as the other Namco NB hardware. Try the pinout for Numan Athletics
http://www.crazykong.com/pins/NumanAthletics.pin.txt
Beep out the 5v and ground lines to see if these line up, then follow the lines for a couple of other things to see if they’re connected and where you would expect (player controls to resistor arrays, sound to sound section etc)
The pinout was the same! Thank you!
Will be available at my event this weekend
195.7 KB
