Nanao MS9-29 Green Signal Issues
ahkek89
Singapore
Hi guys,
so I just got my hands on another MS9-29 chassis. After 4-5 minutes warming up, it exhibits some issues on the green signal where green is flickering or what it looks like bleeding green.
I have no problems with the red and blue signal. See the link the to video. The following were performed but still exhibiting the same problems.
View: https://youtube.com/shorts/AsfMjRLnPTs
View: https://youtube.com/shorts/2IbptQ13Ny8
1.) Suspected faulty transistor on the green signal from the neckboard. Swapped green(2SC4001) with blue.
Result: No change, still showing same symptoms.
2.) Recap the whole chassis.
However, green does not show over bright. Possible cause due to wrong capacitors on the board initially
I have ordered the RGB amplifier chip M51387P aka U201 chip and waiting for it to arrive, as that is my next suspected defective component.
In the meantime, I would like to know if any community members came across the same issue and what was your fix? If not, what would you suggest for this repair.
Thanks in advance!
