Naomi netboot rebooting after 5-10 minutes
kyletwentytwo
UT
Hi all,
I've got a Naomi netboot setup. It works fine, but will reboot after 5-10 minutes in every game I try.
I'm using a Naomi 1 with Netdimm, MP07-IONA for JVS, raspberry pi connected to the four pins on the Naomi, and a Sun PSU. Multi-bios but no PIC.
PSU checks out, I tried it at both 5v/3.33v exact as well as 5.12v/3.37v and had the same issue.
Also tried re-seating the net dimm, as well as screwing it in to make sure the fit was there.
I've ordered a new system fan; mine is a little noisy, but would this really be the issue? I appreciate any ideas.
Thanks!
Edit: I'm a fool and just needed to read the WiPi Netbooter manual. Needed to enable Time Hack, which is required if you aren't using a PIC.
