Need a resistor identification
mathewbeall
Mission Viejo, CA, USA
Hi Folks,
I was helping @bgwelistyl install the NeoGeo HDMI mod, and I ran into an issue where the kynar wire connected to R47 (Clock1) pulled up the resistor and the pad there. I was able to scrape off and bare some of the copper to the left of it, so just need to get a new resistor.
The NeoGeo motherboard is the MV-1C
Can someone validate that R47 is marked "330" - and this this is a 0805 33 ohm resistor? I am getting different answers on the internet as to what the 330 would be.
If it is 33ohm - is there any problem with me using a regular resistor (because I have them), vs getting the SMD resistor?
Matt
Hi,
It could be the value, 330ohm or a code , so 33X10^O = 33ohm .
And yes, you Can put a not smd resistor, no problem. You have a picture ? I have a mv1c and Can try to take a look.
