OEM CF Reader Compatibility
RealMFnG
NorCal
Anyone know if the OEM CF Reader has any special circuitry on it that would keep it from being used with the decrypted dumps? I'd imagine if your Dimm/NetDimm is updated to 4.02 and you have the proper PIC, you can use the OEM CF reader just like the aftermarket Summit Arcade reader or a DIY reader?
Well, i bought an OEM reader anyway. Fingers crossed it works with the dumps.
are you using the correct device id for the compact flash card? or is this completely different for oem cf readers?
Anyone have a link to one of these OEM CF Readers ?
@acblunden2 I saw your post.
That device is solid, you will have no issues.
This version will work on BIOS 4.01 and the non patched BIOS for Chihiro and Triforce since it will always return an ATA ID with a HAGIWARA manufacturer and a fixed serial number.
