Butter Meister
Most IO Boards want 12v and 5v power inputs to run. Normally you'd get these from a candy cab's power plugs, but I don't have a candy cab unfortunately. But Molex from the Type X's power supply is a good enough source. I tested this out with a spliced together cable: 12v and 5v JST's to female molex, running into the case via a PCI slot cover with molex out. The voltages are consistent and everything boots up as it should. I see this as a convenient way to get IO boards powered when you don't have proper power wiring available.
What I used:
PCI Slot cover with Molex - https://www.performance-pcs.com/diy...ver-4pin-molex-3x-3pin-fan-plug-ph-82391.html
Note: The 5v line isn't connected on this thing, you'll have to solder wires to connect it yourself
Molex extension - https://www.performance-pcs.com/cab...ex-psu-extension-cable-30cm-ak-cbpw02-30.html
Get 2 of these, one for inside the case, one incase you wanna recreate my wack ass cable
Is this bad for the power supply?
The PSU's in the Type X series are 400w and have free molex ports. Enough wattage is available and in my tests, my Type X2 still booted and played games as it should.
Molex bad tho
Yes
What I used:
Molex bad tho
Yes
