QMTECH MiSTer FPGA Color case and IO board
china
1. The color transparent shell can be black transparent, red transparent, or blue transparent.
2. Compatible with the casing and Qinmou motherboard IO board, supports SNAC Port, supports 6 USB ports, integrates RTC clock chip and RTC battery, supports Saturn SS video interface output, NTSC Video output, NTSC CVBS output, supports 15.7Khz rgb s/rgbhv output, PCM5102 chip enhances audio i2s output. 6 USB ports, PCM5102 chip enhanced i2s digital audio with no background noise, full video format output HDMI, 15.7Khz rgb s/rgbhv, NTSC CVBS, NTSC s-video can be output simultaneously.
3. Install screws and nylon posts.
1.彩透外壳 黑透,红透,蓝透 可选。
2.适配外壳和勤谋主板的IO板,支持SNAC Port,支持6个USB接口, 集成RTC时钟芯片和RTC电池,支持土星SS视频接口输出,支持NTSC -Video输出,支持NTSC CVBS输出,支持15.7Khz rgb s/rgbhv输出,PCM5102芯片增强音频i2s输出。6个usb,PCM5102芯片增强i2s数字音频无底噪音频,全视频格式输出HDMI, 15.7Khz rgb s/rgbhv , NTSC CVBS,NTSC s-video 可以同时输出。
3.安装螺丝和尼龙柱。
in AliExpress shop: FunFortress Retro Game
  • Like
Reactions: ack
