Repair Log: Irem M72 - Legend of Hero Tonma
ShootTheCore
Utah USA
Received for repair this Irem M72 board stack labeled as Legend of Hero Tonma. It would boot to a corrupted screen.
Checking around the EPROMs, I noticed two things immediately:
1) The ROMs and MCU are labeled for Image Fight, not Tonma.
2) Some of the ROMs were installed in the wrong sockets.
Shifting the ROMs around to the correct sockets allowed the board to boot further than before, but it still froze on a corrupted screen.
I dumped all the ROMs and compared them against MAME. All checksums matched the Japanese Image Fight set, except for two chips (L0 and H0) where the checksums didn't match anything.
Programming and installing new EPROMs for L0 and H0 now allows the game to boot up and display with an almost completely corrupted sprite layer and jailbars displaying over the top of everything (likely the malfunctioning sprites). Music and sound effects are playing fine.
That's all I have time for tonight - more to come! Next time I'll be focusing on the part of the board stack that renders sprites.
Irem M72 is a three board stack, so I decided to swap around one board at a time with my personal working M72 to narrow down a culprit.
Swapping the middle board brought some of the sprites back, but still no text would show on the title screen or on the board self test.
Swapping the bottom board as well brought the game up to what appears to be full functionality, but the self-test shows "ROM NG 1 2".
I confirmed before with my chip programmer that the EPROMs were all good, but I'll try programming and installing a fresh batch next just to be sure. A little Googling also shows that the "ROM NG 1 2" error also appears if the MCU is faulty or is mismatched with the region of the game (ie a World MCU running with a Japan ROM set).
This board will be getting fitted with an M72 Multi so I don't plan on chasing ROM errors too much unless they show up in the self-test for the Multi as well. In the meantime, there's faults in both the bottom and middle board to track down next.
I decided to focus on troubleshooting the bottom board first since it draws the text on the self-diagnostic screen, and I like being able to see those results. The self-diag isn't the best, but it's definitely better than no diagnostic!
The bottom board has two ribbon cables that connect it to the middle board on the left side, and a small power plug that also connects to the middle board on the right side. I can't probe the bottom board as-is, but if I rigged some kind of power harness extension for the right side then I'd be able to keep it connected by the ribbon cables, swing it over 180 degrees, and then be able to probe it while it was running.
Before going down that route though, Googling other repair logs for this board set showed that the four SRAM chips fail frequently, and when they do, they cause the jailbar pattern that I'm seeing with it. Following that hunch, I desoldered all four chips from the board.
Testing them out of circuit revealed that two of them are bad.
I don't have spare SRAM of this type on hand, so I've ordered some chips in that will hopefully arrive next week. In the meantime, I'll solder sockets into these spots and move on to troubleshooting the middle board next.
Most EPROM programmers will let you test SRAM as well. I tested these chips with both my Wellon VP-390 (pictured) and my EETools Chipmax2. The Wellon flunks two chips while the Chipmax flunks three, so I’m just going to replace all four of them on principle. I don’t want to mix the brands or speeds of the chips anyway.
Tonight I focused on the glitching sprite hardware. The sprites were glitching so bad that they were almost not being drawn at all - only an occasional "blip" of a sprite would show up occasionally:
Sprites are driven by some Nanao custom chips on the center board, with ROM data pulled from ROMs C00, C10, C20, C30 on the top board. I'd previously confirmed the Sprite EPROMs had the correct data, so I probed them now with the logic probe to check for stuck lines. They're 27C010 EPROMs.
The address, data and control signals all showed expected pulsing activity on all four chips, so I crossed them off the suspect list for the moment.
Looking at the middle board, everything looked to be in good condition with no damaged traces underneath. The top board covers up most of the middle board when the stack is running, so it's not straightforward to probe it without rigging up something. Before doing that though, I decided to test the sprite RAM. Two out of four static RAM chips on the bottom board had been faulty, and the four Sony CXK5814P-35L RAM chips used as sprite memory have a high rate of failure as well.
After desoldering and testing, three out of the four of them are bad.
I've ordered replacement chips, so that'll be it on updates for a week or two until parts arrive. Crossing my fingers that defective static RAM turns out to be the only culprit on both the middle and bottom boards.
Replacement SRAM arrived for both the bottom board and middle board, so it's time to install the new chips and try things out.
I decided to install sockets and replace all four SRAM chips on both boards so that there wouldn't be a mix of RAM brands and models.
After installing everything and powering up, the sprites are now drawing correctly, but the backgrounds still have vertical jailbar lines. It's not over yet...
Backgrounds are handled by the bottom board, so I needed to work out a solution for probing the bottom board with my logic probe. The bottom board is secured to the middle board with plastic standoffs, which aren't very sturdy to begin with, and some of the standoffs were broken or missing with this set, making them even more precarious. So first, I replaced the plastic standoffs with metal ones to stabilize the stack.
And once the stack was sturdy, I turned the stack on its side and propped it up with some solid anti-static foam and a book.
Now I could safely probe the bottom board from underneath. Checking around the RAM lines, I noticed that I/O 5, 6, and 7 on the middle two RAM chips (IC 34 and 35) never showed any activity. NOTE that a few other IO lines only showed activity at certain times in the demo loop, like when a secondary cloud layer was being drawn.
I traced those I/O lines back to two adjacent 74LS244 Octal Line Buffer chips at IC 44 and 45. Probing on those TTLs confirmed that the outputs for those lines were dead when they should have been triggering (confirmed with the truth table in their datasheet), so I removed both of them. They both tested bad out of circuit.
This time I had replacement TTL parts already on hand, so I installed sockets, confirmed that the new parts were good on the tester, and installed them.
I was feeling pretty good about things at this point, but unfortunately after powering on the background jailbars are still the same:
Crud. That's it for tonight - more diagnosing coming up in the next day or two!
A small update on troubeshooting the bottom board.
After locating and replacing two bad TTL chips through logic probing in my last update, I realized that I have a good opportunity here to try out the in-circuit testing capabilities of my BK Precision 560. The 560 can test most TTL 74 series logic chips without having to desolder them from the PCB as long as you have the same model chip inserted into the tester. The tester runs a logic test matrix appropriate for the given model of chip, and it compares how the chip on the PCB responds against the chip installed in the tester. This way, I can quickly test all of the TTL chips on the PCB - and there's a bunch of them!
One caveat is that the 560 requires the PCB to be powered but not active. On a standalone JAMMA PCB, you'd have to desolder and remove the clock crystal so that the CPU wouldn't execute. In this case, the M72 bottom board doesn't execute anything on its own, and it's powered by a small connector on the side. So all I had to do was connect the board up to my bench power supply and get to testing.
The good news: I was able to test every TTL chip on the board. The bad news: they all passed. Assuming that these test results for all the TTLs are valid, that means that the jailbars are caused by something that isn't physical damage (haven't found any), the TTL chips (tested good), static RAM (verified good) or ROM chips (verified good). That only leaves the three custom Nanao chips as culprits. :unsure:
I want to do a few more confirmation tests with the logic probe before I can say for certain, and of course I'd have to isolate which custom is the culprit, but I may have to look for a custom donor soon. Fortunately @caius is working on reproducing some of them. https://caiusarcade.blogspot.com
The bottom video board uses ony two DIP40 custom ICs marked 'KNA6034201' that are indeed like two big counters connected to data lines of the tiles ROMs so they are most likely the cause of your issue judging from how fault appear.I reproduced it years ago while I was fixing my R-Type that developed same jailbars issue :
https://www.jammarcade.net/r-type-repair-log-and-irem-kna6034201-reproduction/
P.S.
The custom ICs you are talking about (that I recently worked on and reverse-engineered) are located on middle board, they have different package and functions :
https://www.arcade-projects.com/threads/irem-kna70h015-11-and-kna70h016-12-reproduction.17341/
For the next round of M72 troubleshooting, I decided to try a procedure I really should have done earlier - logic probe the behavior of the SRAM and custom chips on my good bottom board and compare the behavior of the bad bottom board against it.
This highlighted a difference in the behavior of Pin 22 of two SRAM chips - IC 33 and 34.
Pin 22 is the Output Enable line and it is shared between the two chips. The line is Active High, and the good board was holding it low most of the time with the occasional pulse high (LPH) while on the bad board, the line was heavily pulsing frequently (P). Thus, both chips were engaging more often then they should be - that could cause jailbars to be drawn, right?!
So where does the Pin 22 signal originate from? It turns out that it comes from Pin 8 on IC84 - way over on the far right side of the board next to the ribbon cables.
I desoldered it and it tested bad out of circuit (!)
However, after installing a replacement, the jailbars are STILL present. :cursing:
I checked the logic behavior afterward and all of the SRAM logic behavior now matches the good board - Pin 22 is now being LPH enabled as it should be.
Ugh, I'm starting to suspect further that one of the custom chips has failed, but the logic probe behavior appears identical between the two boards. I may hook up the logic analyzer next - we'll see. Ten chips replaced so far and I'm still not done. Finding another faulty TTL means that I can't trust the results of my in-circuit testing from last week - there may be another faulty TTL to track down still.
For the next round of bottom board troubleshooting, I rigged up a way to allow me to probe the bottom board from the top side while it is connected and running - I flipped the A & B boards upside down and ran a extended power line between them.
This allowed me to check things much more easily - I could now use my HP Logic Comparator to quickly verify the smaller TTLs as the game was running. I also printed out the relative sections of the schematics - R-Type has schematics widely available and although its top board is missing sound sample hardware that's in all the other M72 games, the bottom board is the same. I also switched from using the logic probe to the oscilloscope so I could detect TTL output line issues where they are pulsing, but not at the proper voltage thresholds.
Between the schematics, comparator and the oscilloscope, I identified three more malfunctioning TTLs - IC 1, IC 12 and IC 59. All three had weak outputs and tested bad out-of-circuit.
Replacing those TTLs cleared up a few tile rendering glitches I'd noticed in the background, but still didn't address the obvious jailbars. Everything kept pointing back to the two KNA6034201 customs on the left side of the board.
The M72 has two background tile generators, and the bottom board is essentially split horizontally across the center where the top half is all the circuitry for one generator while the bottom half is all the circuitry for the second generator. The two circuits are pretty much mirror images of each other. CPU Address, Data and Clock lines come in from the middle board over the edge ribbon connectors, and these signals are shared on both tile rendering circuits, with Chip Enabling lines determining which is activate at any given time.
The final step of the tile rendering for each board half is when the KNA6034201 custom streams graphics data in parallel from the four ROMs, then pushes data out serially through two TTL chips out to the KNA91H1014 SMD Pallette Custom in the lower-left corner - one of the few chips on this board that is shared and not mirrored.
Both KNA6034201 customs appeared healthy - I was detecting active signals on all the input and output lines. However, I was becoming convinced that one or more of the inputs may not be getting "mixed" correctly internally. I decided to remove both KNA6034201 customs, install sockets, and swap them around. If the jailbar appearance and behavior changed just by swapping the two customs around then I'd know that one or both of them were faulty.
Swapping around the two customs made a difference alright - it DOUBLED up the number of displayed jailbars!
I'm forced to conclude that one and possibly both KNA6034201 customs have failed internally. Fortunately @caius has reproduced them, and I've ordered two of them. To be continued once they arrive! :D
This board set must have received a hefty jolt of electricity at some point to cause so many chips to fail.
