Replacement for Ferrite Beads on C board?
Glossectomy
Denver, CO
I had a previously working CE board, that no longer seems to be functioning after pulling it out of storage. Visually the only thing I'm seeing is a broken jumper at FB1 on the C board.
A. Would this be a reason for the board to not boot?
B. Even if no, what part should I be looking at to replace it?
Thanks in advance!
The fb looks to stil be in tact, so shouldn't be your issue.
Do you have a known good set you can use to swap parts?
Check the pal's. If those are good, and theres nos signs of nicked lines, it's probably the b-21 that has gone bad.
