FS Repro DECO Cassette Backplate Interconnect / Power board
SCUBA King
South Lyon
Per the test build thread I posted, the Repro boards are now available for sale.
https://www.arcade-projects.com/thr...-pcb-repro-and-pcbjunkie-jamma-adapter.28005/
While I was piecing together multiple stacks for the @Darksoft DECO multi (available from @Mitsurugi-w ) I found it impossible to find extra backplates.
After finally getting all the boards I needed for that I decided that a repro of the backplate would be helpful for others wo may have loose boards with no way to use them also.
The connectors on this board are uncommon and holy-shit expensive so this repro only has 3 of the 4 slots populated. The original has 4 slots but the system only uses 3 so as a cost save I omitted the 4th card edge connector.
I will have a limited number of these available due to the price of the connectors.
once I sell through this limited batch the price will go up at least $40 due to the cost of components If I need to reload and make more.
it takes around 2 hours to hand build and test each one with over 350 solders (wishlist +wave solder machine) it's a bit of work.
I hope this is helpful to some other collectors who are looking to get that multi running or even to bring back or backup an original with a missing or non functioning base plate.
Also note in this design I had my buddy who did the design for me (@pcbjunkie) add a power header on the inside with correct spacing so if you use the PCBjunkie JAMMA adapter you can route the power neatly inside the cage.
I have not populated the 90° power header for those running on original harness and not jamma. The spacing is correct and the location is ready for anyone who needs that you can drop a 90° header on yourself.
Price shipped on this original batch listed below. Price will be updated if I need to get more parts to make additional per note above.be
$125 PPff
or
$175 PPgs
My pic shows the board outside the cage for testing, also shows my custom 3D printed case for the multi if you want one for your stack:
https://www.arcade-projects.com/threads/data-east-deco-cassette-darksoft-multi-pcb-holder.28008/
