Sega Blast City Nanao / Toshiba ms2931 / 30 convergence fix adjustment (YouTube)
K405
The Netherlands
Stumbled upon this video, thought I'd leave it here for ya'll :)
Also if you need to get your hands on convergence strips you can make your own.
http://forums.arcade-museum.com/showthread.php?t=212081
Ingredients?
- Styrene Plastic cut 1cm x 3.5in into strips
- Kapton tape (link) for HV insulation
- Ultraperm 80 metal (link) cut into 1cm x 1cm squares
- Contact adhesive to stick the metal to the strip
- Double sided foam mounting tape (link) to stick strip to CRT
I've been fooling with mine off and on since I received it. It's moderately improved, but I am still having a tough time with the top right and bottom left. I recently picked up some convergence strips from eBay (ran out of bad Sony TVs to steal them from) and suppose I will have at it again this weekend.
@K405 - thanks for the video.. Could you please post where I can get the strips? I need to use this on a blast.. Thanks
Ok thanks.. I thought that the person in the video was you which mentioned purchasing from the U.S...
This guy may still have some - https://forums.arcade-museum.com/showthread.php?t=368482
I believe I bought mine from ArcadeCup if I recall correctly - https://forums.arcade-museum.com/showthread.php?t=353664
They appear to be out of stock currently though, see http://www.arcadecup.com/ -> Boards/Kits/Misc.
Doesn't hurt to reach out to the seller and see if they can make some more.
You can make your own convergence strips using refrigerator magnets. You can buy blank refrigerator magnets in a big pack at Staples or a craft store.
I think the ones that CRT makers used were permalloy / mu-metal strips. From Wikipedia's mu-metal article:
"The high permeability of mu-metal provides a low reluctance path for magnetic flux, leading to its use in magnetic shields against static or slowly varying magnetic fields. Magnetic shielding made with high-permeability alloys like mu-metal works not by blocking magnetic fields but by providing a path for the magnetic field lines around the shielded area."
Arcade-museum has an old post about making your own strips:
https://forums.arcade-museum.com/showpost.php?p=1926981&postcount=6
I think I still have some off cuts diy strips, if you still need them. If I recap they are only 4.5-5" long. I'll confirm when I get home.
Go right ahead, sorry for the late reply, I don't need any, I went to my local recycling depot and got lucky, they had some stripped monitors on the floor of the shipping container, where they keep all electrical stuff, and ripped a few strips from those tubes.
