Sega JVS IO - I messed up
Sp33dFr34k
The Netherlands
I just started wiring my Sega JVS IO type 1 (837-13551-92).
Started with the power cable from the NVS-4000, fired it up and *POOF*.
EDIT: I messed up (shouldn't have started this after such a bad day) and switched the pins around, DA1 and DA2 started smoking and smell. Guess it's a goner and I need to find a new one :(
I was being an idiot and had the +5V and ground backwards, to end this shitty day...
The DA chips lit up, smoked and now they seem fine but still run really hot. LED1 and LED2 are still lit, however is it safe to assume this is ready for the bin?
Both on the front and the back of the PCB, the chips called DA1-4. You can see they're pretty f'ed up :(
Damn I did the same thing but was lucky I didn't lose the IO but I lost my Power Supply
That is true. I've just finished wiring P1 up, and uhhh, it still works to my surprise :)
I've measured the temp of the chips with the probe of my multimeter and it shows a steady 45 degrees celsius. So pretty warm, but not hot. Not sure if that's normal?
Might be best getting a replacement anyways, but was just curious if that's normal behaviour for those chips.
