SOLD Seimitsu joysticks: LSH-56-01 Anomalous Spring
andynumbers
Atlanta, GA
Condition is "like new" on all sticks. Sticks were installed in control panels and rarely used.
Must be sold in pairs.
LSH-56-01 Anomalous Spring: $21 each
A limited edition version of the LS-56 with a special spring and a permanent frosted shaft cover. Octagonal gate is installed from the factory on this stick. Black balltop available on request.
I can vouch for the 56-01s with the Anomalous Spring. They’re fantastic short throw sticks. I have 3 total (2 in my NAC and 1 in a Mayflash F500). Arcadeshock was the original distributor and noted only 1000 were made (who knows if that will be forever). Probably the best stick besides the LS-62 IMO. GLWS ✌️
Thanks. No response from OP, so I assume they were sold. But I did get DM'd by someone else with an LSH-56 to sell, so it's on the way. Out of curiosity, what is it about the ls-62 you like even better? The shorter shaft is not as appealing for me, especially since the enclosures I've made tend to have thicker tops (current one is an old RRoD 360, but has a small, plastic cutting board epoxied in to distribute the force and to screw into, for example).
The best way I can describe the LS-62 is the LS-56 with a shorter, LS-32 shaft. I don't care for shaft-covers.. I use a SS plate and a square gate from a LS-56 on my LS-62 and it's pretty nice. You can't go wrong with either. =)
The best way I can describe the LS-62 is the LS-56 with a shorter, LS-32 shaft. I don't care for shaft-covers and IIRC you cant remove the shaftcover on the LS-56. I use a SS plate and a square gate from a LS-56 on my LS-62 and it's pretty nice. You can't go wrong with either. =)
Thanks for the quick and helpful reply! It's probably not for me then. I use the Kowal short throw mod on the 56, and it's a pretty short throw with a longer shaft. Considering where these levers get mounted for me, the LS-56 (and soon the LSH-56) with the ST mod are probably the right choice for me.
I know the LS-32 have a different shaft, maybe you're thinking of that?
The above link applies to these sticks-
  • LS-33
  • LS-40
  • LS-40-01
  • LS-55
  • LS-55-01
  • LS-56
  • LS-56-01
  • LS-58-01
Update: The LSH-56-01's are for sale again. I decided to go a different route on my supergun control panel and change sticks. I no longer need these. They are still in brand new condition as I didn't really use them at all. Same price. $42 plus shipping. These are no longer available so here's your chance. Black ball tops available on request at no extra charge.
