Seimitsu SE (P=40) replica
NFGx
Brisbane.au
I picked up an LS-55 recently, but it came with their MS plate, which didn't fit my panel. So I whipped up a copy of their SE plate, which does.
This will support any of their smaller 40mm sticks (Which is just about everything but the LS-32, LS-40 and Nobi sticks).
It's plenty strong enough to play when the plate is mounted flush against the panel, since the mechanism itself provides most of the structural integrity. But just in case I added some extra walls on it.
STL file is available here.
Wow, WTF. The permissions are set to allow guests to view and download attachments, because forums that don't let people do that annoy the piss out of me. I mean, I get it, but that's not what I want for my own forum. So I'll have to check in with the SMF guys and see if it's a bug or if somehow '☑️ enable attachments for guests' doesn't do what I think it does.
I've moved this particular plate to the wiki, where it definitely works when you're not logged in:
https://gamesx.com/wiki/doku.php?id=arcade:3d_printable_parts#seimitsu_se_p_40_plate
Thanks for letting me know it doesn't work. It was not the intent.
I have a login but even after doing so, it tells me I do not have permission to view the files.
That's doubly strange, because ALL user groups have this permission enabled. Have you made at least 1 post already? That's the step that gets you moved up to 'normal' user status. Can you message me your username, and I'll dig into that a little more?
I don't think I made a post. Should have dawned on me, so thank you.
Well I've been digging away at this with the help from the SMF guys and there was definitely some weird stuff going on as well as some overlooked stuff. I think I've managed to add permissions for members to download the files now, can anyone confirm that?
It still doesn't work for guests, but this isn't true for the rest of the forum. There's something special about the 3D printing board, and my apologies for that oversight. I'm working on it.
I had an order for some 3D prints. I wasn't sure when this would be available for download, so I placed my order without your LS-40 mount. No worries.
Ah, well you could have downloaded it from the wiki too...
But I just fixed the broken board, so you won't have to suffer next time. =)
