Thunder Dragon 2 Enhancement Hacks
Hatsune Mike
Tokyo, Japan
I've made a set of small patches to Thunder Dragon 2. The following features are added:
* P1 Autofire on button 1 (no need to add interstitial JAMMA adapters)
* P1 button 3 mapped as non-auto button 1
* P2 is able to start a game without P1 joining (even with multiple credits inserted / free play)
The IPS patch and sources are available from https://github.com/Mikejmoffitt/td2-enhancements .
Wow, awesome!
Pretty much all the reasons why I traded mine away :(
Very cool, haven't played this game before but it looks pretty rad.
* Free Play with attract mode (enabled with unused DIP switch 1.4)
This sounds really convenient. Thanks for making this available!
I'm testing out these patches and while the autofire is really nice to have, I'm not able to start a game with free play enabled on 2P ship only. If I press 2P start, it begins with 1P and 2P. Do the dip switches have to be set up somehow special to enable this feature? I have SWB 1-4 on for free play, SWA-7 on for no demo sounds and the rest off.
Also, I noticed that originally you had stated that DIP1.4 is unused, but according to this page, it shows as used for difficulty select: https://www.crazykong.com/dips/ThunderDragon2.txt . I've been using that page for reference, is it correct? Thanks!
The Free Play is a bit of a silly episode. I didn't realize that TD2 actually offered its own Free Play mode, so I hacked in one completely of my own. Then, a friend pointed this out, so I removed mine.
If you have the old build with my own Free Play, then it's DIP 1.5 - that was my mistake in noting which one is used. In that case, you should leave SWB1-4 to a coin setting, and set SWA 1.5. Then, you will have my Free Play, which lets 2P join without 1P.
The old version with my Free Play is available here: https://github.com/Mikejmoffitt/td2...6ed9147584712609/td2-enhancement.ips?raw=true
(it is also 666 bytes, which rules)
