Axun Workshop - Arcade PSU (Power Supply Unit)
drfunk2k
From USA / Nanjing, China
PRICE:
$80.00
SHOP: http://www.axunworks.com/product-p669351.html
FEATURES:
- AC input voltage is universal, with switch and fuse
- DC output +12V 3.5A, +5V 8A, -5V 0.5A
- 5V is adjustable can be fine-tuned
- dedicated quick connect cables for the HAS, MiniGun, SHOGUN, and NAMCO 256 (SOLD SEPARATELY)
White Plug Interface reserved for later support such as Namco System 256 cable
I'm definitely down to buy these once my PSUs crap out.
Not sure if you mentioned it in another thread, are you discontinuing Supergun orders?
HI. There is no suspension of Supergun orders, you can buy it at any time if you want. It’s just that there are a lot of orders and it takes some time to make these.
Outer diameter: 9.9mm , inner core diameter: about 2.3mm (17AWG)
Uses: sensors, power lines, signal lines, PLCs, servo signals, drag chains, tank chains, manipulators, robots, etc.
Features: soft and fold-resistant, anti-ultraviolet, working range of minus 40-105 degrees, oil and acid resistance
@Axun what gauge is the wiring for the power cables?
DOPE! Thanks for the info. SOLID! <3
Do we have an estimated update with PSU orders? I personally have loose expectations, had some fans reach out for an estimate, figured i'd drop the Q here.
