DARKSOFT Darksoft's MultiMVS Latest Firmware, Menu and Instructions
hi darksoft
Thank you for your message.
Motherboard mv2f consolized with universe bios 3.2 et mv2 original with original snk bios ( i've try with the two but it's the same)
ABOUT:
Firmware revision : 0x044e
firmware buil : 0xa160
top buil file: 0x35bb
Diagnostics:
FPGA STATUS : READY
BACKUP RAM ACCESS : OK
BACKUP RAM: OK
FILESYSTEM: OK
FILESYSTEM SIZE : 4MB
FILESYSTEM READ SPEED : 49152 B/S
FILESYSTEM WRITE SPEED : 44683 B/S
MENU ROM CHECKSUM : faf97a4d (write purple color)
Thank you by advance
Best regards
MARCOS
I've never seen that error so it must be related to a bad contact. Did you check/clean them? Is your console working 100% with other games?
hi,
The mother board contact or the cartridge contact ?
I've not clean them but i have more of 50 original mvs games working perfectly.
I have 2 different mother board ( double slot mvs mv2 and mv2f , with same issues on the 2 mother board )
Thank you
I've try with with an arcade power supply 5v/15A 12v/2.5A
And with other one , a power supply than i use with naomi netdimm.
Maybe the MV2 and MV2F slot are not 100% compatible?
Which motherboard is the least problematic with darksoft multi mvs please?
@marcos that Firmware that you have is very old. Please update to the latest.
Are you using a microSD SDHC? It won't work with SDXC.
I've update with the latest firmware and it's worst now .
i use a sdhc samsung 32 evo
Which PSU are you using? Have seen some issues in the past with consolized units with too weak PSU
I've try with 3 different psu and always same issues:
update like this ?
first flash, mvs on for update,mvs off, i remove sd card.
2 top , mvs on for update , then mvs off , remove sd card .
3 remove cartridge, mvs on clear up backup nvram. put cpld for update and mvs on.
menu was already the last one (22 nov 2019)
But always full of graphics glitches.
I don't understand.
Maybe the cartridge have an issue, no ?
You can't mix menu and firmware versions. That's why they are given together. Put all files on the microSD and let it power cycle and finish the update.
I followed the instructions but when i place the new menu on a folder called “menu” inside \update the folder \menu inside \update was not deleted.
Something is wrong with my cartridge, i've buy on ebay ( the seller says it works perfectly.)
, this cartridge never worked properly on my two models mother boards (graphics glitches).
And he said i must use with a mv1fz.
My 2 slot mvs mv2 and mv2f working properly with original games.
Where can i see a correct video for updating this cartridge ?
i did the update on another sd card to keep the seller's sd card as i got it for safety. I copied his sd card to mine to update.
Maybe i must send it back to the seller ? What do you think ?
* i'm not a beginner in arcade, i have pcb game, mvs, cps1 cps2, igs pgm 1 and 2 , type x2 multi , naomi net dimm. all working perfectly at home.
I don't understand what's going on with this cartridge.
It should not be neccessary anymore but put the menu files into the games\menu folder, too. Maybe ist helps...
