Go by RC / RC de Go booting ?
I tried booting the copy of Go By RC I have for you to see, but I have no original controls. I'm trying with a known good CF card.
It boots to control calibration which I can bypass with start/test. Then I land at the normal test menu... But when I exit that test menu, it reboots straight to control calibration again.
If you want to try it anyway, grab the file from http://neohyphengeo.com/GNET/ (already extracted from CHD)
that's normal behaviour when you fail to calibrate.
if you touch the pins of the analog header during calibration you can get the reading to jump and fool the game into passing calibration.
I've tried again with that pre-extracted version, but the behavior on my board is the same, reset loop.
I never get to see a controller calibration screen.
Guess I must have the super rare NObyRC G-NET board :/
The anoying thing is that I might have found a nearly plug-and-play solution to use a regular RC receiver and controller but I'm now unable to test it out.
If anyone wants to give it a try here is a link to the little converter board: PT01B
Thanks for all the support, not sure if V2.0 BIOS and then back to 2011 ModBIOS would help but it looks like my last test to do.
@skate323k137 what are the dip switch settings you use on your board?
On mine they are all set 'off'. I can't find much information on the G-NET dips beyond dip 4 being used for booting into test but I'm wondering if there is anything that controls the use of the analog inputs.
Now that you mentioned this, I want to say this is an actual thing. I seem to remember some batches of G-NET having issues with certain games? I had a G-NET board at one point on which I couldn't get a legit Soutenryu to boot. I remember discussing this with Joerg / Arcademodbios back in the day and he confirmed it was a genuine issue (at the time).
EDIT: looked through my emails and the problem games were RC de Go, Soutenryu and Shanghai Shoryu Sairin. @neokoen, try booting the other two.
Just tried Soutenryu and Shanghai Shoryu Sarin and indeed, they also go into a reset loop X(
Don't care about those two mahjong games but GObyRC is a real bummer since I'm also running RC cars hence why I wanted to run that game with my regular controller/receiver.
Just for reference then I guess, the FC PCB has labels "K91X0721A G-NET MOTHER" and "M43X0337A 277104335"
@nem I assume there is no know method to make my board accept those games?
Anyone have a known "good for GObyRC" G-NET board they want to part with?
Old thread bump, but I have a G-Net here with this exact issue, however one additional game it won't boot is XIIStag. The RC de Go is a legit PCMCIA card, the rest are all Sandisk cards which work fine when written to with other games.
Do we have any idea what's specific to the hardware revision that might cause this? I kinda bought a G-Net specifically for RC de Go, so it's a bummer it doesn't work.
Afaik this is still unknown. I've tried digging into this a while back, but no info to be found. Also tried identifying comparing serial numbers of known "good" and "bad" ones, but no pointers there either. Seems the only way is to sell your PCB and buy a known "good" one which boots those games sadly.
From my limited sample of ZN-2 boards.
1-665-825-11 with blue DIP switches will run RC de Go.
1-665-825-12 with orange DIP switches will not run it.
I have a board with blue dip switches that does not run RC de Go ..
Where is the serial number you mention located on the board ?
So the -11/-12 seems to be the indicator. For testing I also swapped over the g-net bios to a -11 ZN-2 capcom motherboard and it worked with rc de go. From comparing the 2, I saw one sram was a different brand. Swapping that over did not change anything. So the difference must be somewhere else.
Just checked, mine is indeed -12 with blue dip switches. Guess I will keep an eye out for a -11 ZN-2 to use. :)
So this thread intrigued me because I have 6 gnet boards... I own 6 because I had been collecting them to have a full multi player go by rc setup
In any case all 6 of my boards are -12 with blue dips. 2 of them have issues in general so aren't good to judge but tested the remaining 4, 3 of them boot and play go by RC just fine.
If you look along the edge of the mobo there are the letters A B C D E F G H and one of them will have a sharpie mark over a letter. Of the 3 boards that boot: A or B are marked.... The one that works for most games but not for Go by RC has C marked...
Maybe not definitive but I haven't noticed any other differential markings.
Weird. Mine has A marked.
