Good PSU replacement options for X68000 XVI
quarkstarmuffin
United Kingdom
My machine had a recapped original PSU so I thought I'd be ok for a while but it gave a nasty crackling noise when I turned on the power switch today and promptly died, so I need to figure out a good replacement option. I'd prefer to avoid external modifications if possible and also keep things tidy inside. Are there any particularly clean solutions for this that people would recommend?
The soft power button is fussy and acts up frequently with the original power supplies too. There's details here, along with an app you can run that will tell you if it can detect a problem with your computer's soft power.
https://gamesx.com/wiki/doku.php?id=x68000:soft_power_switch_troubleshooting_and_repair
Honestly, even though the soft power works fine with my PicoPSU, I always turn the computer off with the hard switch in the back anyway. The X68000 doesn't "deep sleep" in the same way that modern PCs do - the power supply will stay powered to preserve the X68000's RAM when the soft power switch is off.
