How to Create a Zero Key (PIC) For Net Booting and CF on NAOMI Chihiro and Triforce
I can't seem to get this to work. I burned the file with my GQ-4X using the settings provided. The game loads and verifies, but I get error 33 Gateway not found once the game tries to actually boot. Anything else I can try? I've tried a few different games.
You have set the jumper settings to Netboot mode on the DIMM as well ?
Yup. This is my setup.
Error 33 is almost always the PIC.
You could try using transfergames.exe, since it lets you netboot without a zero pic. It can be found in gakman's repository, in the tools folder.
It's a good way to find out if your pic is faulty or not.
It might be the PIC, it might be programmed incorrectly.
Anyway I took the binary from the first post, burned it to a PIC16F628A and tested it on my setup, worked 100%.
Check voltages, run RAM test, check network settings.
I did the test with transfergame.exe.
edit:
when writing the device did you verify that it was erased before programming ?
@kioku25 transfergame.exe does not let you netboot without a PIC inserted.
If you use transfergame.exe without a PIC you will get:
ERROR 31
THIS GAME IS NOT ACCEPTABLE BY MAIN BOARD
I just verified this on my system :D
ERROR 31
It's been years since I messed with those programs and my memory is a little hazy it seems.
It was the python script naomi_boot.py that ran without a zero pic and not transfergames.exe.
I can't seem to find it in gakman's repository, but the internet archive has you covered.
With python installed you only needed to run the following command: python naomi_netboot.py gamename.bin.
It's been years since I messed with those programs and my memory is a little hazy it seems.It was the python script naomi_boot.py that ran without a zero pic and not transfergames.exe.
This was done by tmbinc a long time ago.
https://debugmo.de/2009/04/triforce-tools/
His script is a straight implementation of transfergame.exe in Python.
edit:
checking the python code there is an explicit function to write a zero key to the system.
ABC_BIN_0000000000000000_NET.bin
Confirmed working on a top3000 with settings:
under windows 10
note: on windows 10 the gui freezes for a moment and says (not responding) but just wait it comes back once is done.
GQ- 4X4 has no issues
no errors with PiForce Web
Thank you rtw :thumbup:
I was looking into why I am still having issues burning a Chihiro Netboot Capable Zero PIC (as opposed to a CF Zero PIC) and I ran across this seemingly interesting comment in the code disassembly at http://pastebin.com/Wn33TXMk
"When programmed with a Wellon VP-280 or pickit2 - it is confirmed working like the original PIC"
I have a PICKit 2, and when I tried to flash an older PIC16C621A or PIC16C622 like many of the original Sega Keys are. I noticed that I was unable to use the PICKit 2, it actually only supports the replacement chip that everyone latched on to PIC16F628A since it was binary and pin compatible per http://wiki.pcbotaku.com/wiki/NAOMI_security_PIC
I am not sure if this is *useful* information, but I thought it may help unravel why some folks are having issues with some of their failed attempts. FWIW the VP-280 lists all three PIC16F628A, PIC16C621A and PIC16C622 as supported. http://www.weilei.com/VP-280list.htm#MICROCHIP
I made a file some years back called 5 abc Net or something similar. I'm sure I shared that one. It was not new I simply wanted to make it myself.
I'll have to check my troublesome chihiro keys. Thx dude.
I had a real hard time finding a zero PIC that would netboot my Chihiro type 3. Mitsurugi burned me two before he found a working one and I had bought two non working ones from a previous seller as well.
I can confirm using trmm's top3000 settings worked for net booting chihiro type 3 with piforce-web. Tested with Virtua Cop 3. Thank you
@zeruel85 can you load this into you programmer and show us how the bits are set ?
I'm using a GQ4x4 programmer and using the binary file I set the config bits (0x3F82, the same as your hex file.) and I got Error 33. I then tried to set the config bits to what trmm showed above and still got the Error 33.
However, once I tried your hex file everything started working.
I then looked at the buffer and noticed the GQ software is byteswapping the data, is there any reason NOT to use the hex file you provided?
I found this too, with the older GQ4X. Simple byte flip before writing sorts the Error 33 issue.
I have a hex file which I believe should create a single PIC that can do both netboot and CF loading.
Thanks rtw! Tried a few other Zero Pic bin files with no luck. Yours worked, but needed a little trial and error. Used a Top3000 (via usb only) and tried settings from the OP and trmm, but for some reason it was only writing zeros to the PIC16F628A chip (tried a few different chips) . Here are the settings that ended up working for me:
OSC - HS
WDTEN - 0 Disable
PWRTE - 0 Enable
MCLRE - 0 Disable
BODEN - 0 Disable
LVP - 1 Enable
CDP - 1 Disable
CP - 1 Disable
User.ID ffff
MFA.ID 5068
I'm reasonably certain that the attached hex files should produce a single PIC that will allow both netbooting and CF loading (ABC.BIN) of decrypted game files. One should just have to set the DIMM jumpers accordingly.
I've included two versions; a 'normal' one and a byteswapped one. I had to use the byteswapped one with GQ USB Programmer software and my GQ-4X programmer, writing to a PIC16F628A chip.
I've tested CF loading on NAOMI with a 4.02 net DIMM. I'll leave netboot testing for someone else to try. :)
I'd also appreciate someone testing both CF loading and netbooting on Triforce and Chihiro setups, since I don't have either!
Updated the first post with compatible systems.
The Net-Boot PIC is fully compatible with Chihoro.
In other words you do NOT need a special PIC for Chihiro.
So a Netboot Net Zero PIC for a Naomi 1 or 2 WILL work for a Chihiro Type 3?
Can a Net Dimm work in terms of Net booting with anything but a Net Zero PIC? - In other words, I have a Net Dimm that is able to Netboot fine - can I assume it is a Net Zero PIC? If not - what are the advantages of it being a Net Zero PIC versus an "ordinary" PIC?
