Is there an SCSI ODE with Audio Support?
twistedsymphony
Enlightened
Staff member
Immortal
NH, USA
I recently picked up a Konami GV System, specifically Susume! Taisen Puzzle Dama. This system uses an SCSI CD-ROM drive similar to CPS3, UNLIKE CPS3 however it does use the CD for in-game music. So it's got your typical data-track with the game code then a series of audio tracks on the disc.
The drive on the unit I bought was dead, I did swap in my CPS3 drive to and got the game booting. The jumpers have to be configured for termination, as well as drive ID "2" and the parity jumper needs to be set as well.
This was enough to use the CPS3 drive on this hardware and get the game playing, but unfortunately the CPS3 drive uses a non-standard Audio connector so I couldn't get that in and the game was missing music.
I managed to find another drive of the same model as the original GV drive on eBay to replace it, but I'd like to use an SCSI ODE for easy game swapping, faster loading etc.
Unfortunately it seems that most of the SCSI ODEs don't actually have support for audio.
The one I did find was MacSD https://www.tindie.com/products/ymkdevices/macsd/
Contacting the shop selling this it seems however that it doesn't support the parity function for CDROM emulation, which makes it a non-starter.
Anyone know of any other alternatives here?
There aren't a whole lot of titles on this platform, and even fewer good one but the only thing that needs changing per game is the EEPROM and disc. So I do wonder if some simple disc patching and then an ODE with a disc selector would essentially allow you to DIY a multi here.
for anyone interested I got the drive in today and got the game fully working again. Would still love to replace with an ODE. the game actually had the classic PS1 era freeze for 2 seconds when switching scenes as it spins up the drive and then delayed music start as it seeks to the right position, so an ODE would make a nice upgrade.
I did also swap from the JP version of "Susume! Taisen Puzzle-Dama" to the English Language Asia version "Let's Attack Crazy Cross" by just burning a new disc. Most games can be swapped by changing the disc and re-flashing the EEPROM. the region swap on this game though didn't require an EEPROM update. though I did have to boot up while holding the test button to reset the settings portion of the EEPROM before the game would boot with the new disc.
Reactions: nem
Doing some more searching I came across this thread: https://www.vogons.org/viewtopic.php?t=94513
which lead here: https://68kmla.org/bb/index.php?threads/dac-attack-for-zuluscsi-audio.44480/
and here: https://github.com/saybur/dac-attack
basically a newer ZuluSCSI firmware added audio support and this person designed an add-on board called "DAC Attack" to add in add in the necessary hardware and connector.
Two problems with this
1 is that I would have to fab this add on board myself (not a big problem but annoying and time consuming), and
2 the ZuluSCSI RP2040 board needed as the base was sold out nearly everywhere unless I wanted to pay some way inflated prices.
So I contacted Rabbit Hole Computing asking when they'd get more in stock and asked if they were considering carrying the DAC Attack board only to discover that they were literally releasing a new Zulu SCSI board TODAY that includes an optional audio board:
https://shop.rabbitholecomputing.com/products/zuluscsi-blaster
it's called the ZuluSCSI-Blaster or the ZuluSCSI RP2350B
The reason the older ZuluSCSI RP2040 was sold out is that they were depleting stock of the old version before releasing the new. So I've just placed my order and will report back once I get it in and have a chance to set it up.
I got in the new ZuluSCSI with the Zulu Blaster Audio DAC Unfortunately I haven't got it to work with the Konami GV yet.
The specific drive that my hardware uses is the Sony CDU76S: http://insight.actapricot.org/insight/common/drives/cd/so76sc.htm
The jumpers in the back have "Parity", "ID2" " and "Test Mode" jumped (unsure what test mode does).
The Prevent/Allow Jumper is removed (which disables the eject button on the drive).
The Bin/Cue Image I'm using with the Zulu for the disc is the same bin/cue I used to burn a CD-R to play in the drive so I know that's correct. and I have it labeled CD2.cue and CD2.bin (this is the way the new firmware sets the drive ID)
When you boot up this hardware it does some system checks then does a "Media Check" where it compares some data on the CD to data stored on the GV board in an EEPROM as a security check, so if the drive is bad or you're using the wrong disc then it fails this check and the system reboots and starts over. and it's failing that check.
I don't think it's locked to any specific model CD-ROM drive as these GV systems also sometimes shipped with a Toshiba XM-5401B and I did grab a completely different model drive from a Capcom CPS3 setup (Panasonic / Matsushita CR504-KCM) and it ran from that drive fine once I configured the parity and ID jumpers correctly (it's worth noting that the CPS3 drive does not have a "test mode" jumper nor a prevent/allow jumper).
I've attached a couple of log files from my attempts one where I used an ini file and one where I didn't (the settings seem to match all the defaults)
this is the log file I'm getting when the system reports "BAD" on the media check step
Code:
[10ms] Platform: ZuluSCSI Blaster
[10ms] FW Version: 25.03.10-release Mar 10 2025 21:46:43
[11ms] DIP switch settings: debug log 1, termination 1
[11ms] SCSI termination is enabled
[12ms] Flash chip size: 16384 kB
[12ms] SCSI target/disk mode selected by DIP switch, acting as a SCSI disk
[13ms] I2S audio to expansion header enabled
[13ms] Reclocking with these settings are compatible with CD audio playback
[14ms] Initial Clock set to 150000000Hz
[15ms] Reclocking the MCU to 200400000Hz
[15ms] Setting the SDIO clock to 40MHz
[16ms] After reclocking, system reports clock set to 200400000Hz
[16ms] Starting Core1 for audio
[154ms] SD card detected, FAT32 volume size: 30497 MB
[154ms] SD MID: 0x1B, OID: 0x53 0x4D
[154ms] SD Name: GB1QT
[154ms] SD Date: 1/2018
[155ms] SD Serial: 0xDD9D5D87
[2694ms] Reading configuration from zuluscsi.ini
[3008ms] Active configuration:
[3008ms] -- SelectionDelay = 255
[3009ms] -- EnableUnitAttention = No
[3009ms] -- EnableSCSI2 = Yes
[3009ms] -- EnableSelLatch = No
[3010ms] -- MapLunsToIDs = No
[3010ms] -- EnableParity = Yes
[4619ms] Finding images in directory /:
[4799ms] -- Opening /CD2.bin for id:2 lun:0
[4949ms] DBG ---- Image file is contiguous, SD card sectors 63198 to 1067694
[4950ms] ---- Configuring as CD-ROM drive
[4950ms] ---- Read prefetch enabled: 8192 bytes
[4950ms] ---- Found CD-ROM CUE sheet at /CD2.cue
[4954ms] ---- Cue sheet loaded with 35 tracks
[5040ms] -- Platform supports ROM drive up to 15804 kB
[5041ms] ---- ROM drive image not detected
[5041ms] SCSI ID: 2, BlockSize: 2048, Type: 2, Quirks: 0, Size: 502248kB, Removable
[5042ms] Found 1 removable device, to set an eject button see EjectButton in the 'zuluscsi.ini', or the http://zuluscsi.com/manual
[5225ms] Clock set to: 200400000Hz
[5225ms] Initialization complete!
[17938ms] DBG BUS RESET
[19305ms] DBG -- BUS_BUSY
[19305ms] DBG -- BUS_FREE
[19573ms] DBG -- BUS_BUSY
[19573ms] DBG -- BUS_FREE
[19840ms] DBG -- BUS_BUSY
[19840ms] DBG -- BUS_FREE
[23317ms] DBG -- BUS_BUSY
[23317ms] DBG -- BUS_FREE
[23584ms] DBG -- BUS_BUSY
[23584ms] DBG -- BUS_FREE
[23852ms] DBG -- BUS_BUSY
[23852ms] DBG -- BUS_FREE
[24119ms] DBG -- BUS_BUSY
[24119ms] DBG -- BUS_FREE
[24387ms] DBG -- BUS_BUSY
[24387ms] DBG -- BUS_FREE
[25724ms] DBG -- BUS_BUSY
[25724ms] DBG -- BUS_FREE
[26526ms] DBG -- BUS_BUSY
[26526ms] DBG -- BUS_FREE
[27863ms] DBG -- BUS_BUSY
[27863ms] DBG -- BUS_FREE
[28666ms] DBG -- BUS_BUSY
[28666ms] DBG -- BUS_FREE
[30003ms] DBG -- BUS_BUSY
[30003ms] DBG -- BUS_FREE
[31608ms] DBG -- BUS_BUSY
[31608ms] DBG -- BUS_FREE
[32143ms] DBG -- BUS_BUSY
[32143ms] DBG -- BUS_FREE
[32410ms] DBG -- BUS_BUSY
[32410ms] DBG -- BUS_FREE
[32677ms] DBG -- BUS_BUSY
[32678ms] DBG -- BUS_FREE
[32945ms] DBG -- BUS_BUSY
[32945ms] DBG -- BUS_FREE
anyone have experience with the Zulu or any other SCSI emulator that sees anything obvious I might be missing?
