MV-2FS lines on screen / corruptions
Flain
Sydney, Australia
Hi All, my MV-2FS started recently displaying some issues, see below. It's not the game cart as it happens no matter what cart i put in,. Does anyone have any hints as to what might be going wrong with my board?
Does cleaning the contacts on the multi, reseating it as well as the SD card fix the issue?
Yes. Usually this corruption is a dirty slot. The fact it’s also happening with a 161-in-1 points to that. Let us know how ya’ go.
It's a problem with the C-ROM access. Either dirty/bad contact as said, or broken data line.
This is also a symptom you will see if you have battery leakage as its right next to the C rom data lines.
Thanks for the suggestions guys. I got around to cleaning the slots, they both looked clean already (its a 2slot board, i cleaned the slots anyways) and the problem still happens regardless of which slot i use so i suspect it's one of the other problems suggested.
I'll have to see if there is any traces that look damaged? There also doesn't appear to be any leakage of the battery.
