NAC Splitfire: JAMMA streaming solution
I recomend a framemeister. Some capture cards are quite picky with their input resolution.
Since most will accept ony 720 or 1080p
and ossc will just double the resolution giving you:
448 (x2), 672(x3), 896(x4)
Older Capture cards might accept this kind of numbers thou.
So check out what your Capture Card does accept beforehand.
Any suggestions on getting a VGA signal to something the Framemeister can detect? I only use the OSSC just because it has a VGA in.
You guys should make a separate thread to talk about this.
20 of 57 shipped? Where are these numbers coming from?
The post is @hoagtech 's but I am definitely not going to be updating a big list with each one. Maybe in batches.
I coalated your thread from the beginning.
Their was no mention of fulfillment.
If you send your fulfillment I would be happy to update.
