Neo Geo MV25UP-0 Restoration
mob-z
Saudi Arabia
I have been putting of this project and prolonging it for quite some time, trying to find an excuse to stay away. But I have decided that it is time.
When I first started working on the cab, I had power issues (not enough power to run the main motherboard). The screen would turn on, but it would just be static/green screen.
After resorting to the good people of this community, I was finally able to make it come alive! (special thanks to nem for helping out) which can be viewed here (https://www.arcade-projects.com/threads/help-with-neo-geo-mv25up-0.26541/)
After being able to power up the arcade and made sure that it was fully functional, I decided to strip everything apart, making sure to take a lot of pictures and label all the parts in order to remember where everything goes when I put it back again.
I started off by removing the main board, and as you can tell, it hasn't been cleaned up in quite some time. Below are pictures before and after cleaning.
The cab wasn’t too dirty but also wasn’t too clean to begin with. I had to take it apart as I was able to spot rust in different places, which suggest that either could be due to bad storage or kids spilling their drinks while playing 🤷‍♂️ who knows!
The first thing I started with was the control deck since it was an easily removable part, or at least that’s what I though…..
The deck was locked from the bottom, and I didn’t have the keys to open it, so I had to come up with different ideas, but ended up using a drill to make a hole through the lock itself, luckily, no damaged wires.
Not too bad, just lots of dirt. That MV-IC needs some serious cleaning!
Interesting to see the manufacturing date on this cab. If I’m translating this correctly, this would mean that this cab was inspected around 26th August 1993 (since the arcade was released in the 1990s), correct me if I’m wrong!
To be continued...
The next step is to remove all the wiring and put it aside for the time being, keeping in mind where all those ground wires go when rewiring.
I might need to change the control panel overlay since it looks a bit worn out! I will try to give it a bit of cleaning if it helps, probably towards reassembly.
Taking my time to disassemble all the parts.
Finally, I have successfully finished disassembling all the parts. Rust can be seen on the base, which will require some good sanding to remove it.
The monitor on the other hand looks good but the board would definitely need a good wash to remove all the dirt.
20230721_001438.jpg20230721_005831.jpg20230721_001416.jpg20230721_001421.jpg20230720_234642.jpg
Next will be paint removal.
To be continued...
I Started to remove the paint from the cab, I was struggling with this as it was one layer of paint after the other. This is due to the fact that the service dept in the gaming center did a poor job servicing their cabs, mostly repainting on top of the original paint, either using a paint brush, or spray paint.
At first, I tried to removing the paint using sanding paper, it gives great results, but that turned to be a big hassle and time consuming.
So instead, I opted for a second option, which was using car paint stripper, followed by sanding paper.
We found a culprit! Lot of rust hiding behind the layers of paint! This will definitely need a lot of sanding to ensure a good paint job!
To be continued...
After struggling with paint removal, I have finally finished the hard part. This process took quite a bit of time, which took around 2 weeks to remove the old paint.
I was able to take the cab to a body shop last weekend for a final clean-up and a fresh coat of paint.
Image 2024-05-26 at 14.48.11_4c0dd44c.jpgImage 2024-05-26 at 14.48.12_7c7ed82c.jpgImage 2024-05-26 at 14.48.12_08c21c0a.jpgImage 2024-05-26 at 14.48.12_9c2f3e69.jpgImage 2024-05-26 at 14.48.13_3accdd92.jpgImage 2024-05-26 at 14.48.13_a8a879d8.jpg
I had left the inner paint in the main cabinet due to the fact that it was a clean (and most likely it was the manufacturer paint) and there was no sign of rust in that area. So, I opted to leave it as it.
Will follow up with the pain shop in 2 days to make sure that the paint has dried before taking the cab back home for reassembly.
To be continued...
I've been quite busy last week and wasn't able to post any updates, but at least I was able to pick up the cabinet from the paint shop, and the results are great! I will let the picture do the talkin'.:D
Hopefully my last step is to assemble the whole cabinet and see how it would look like with the new paint job. Looking forward to this!
To be continued...
At last! I was able to complete this project and the results are amazing! I am very happy how it turned out!
This cab has seen worst days, but I promise to give it a good home 😄
20240527_164053.jpg20240527_170915.jpg20240527_192930.jpg20240527_201429.jpg20240528_085911.jpg20240527_230211.jpg20240528_125518.jpg20240528_175642.jpg20240529_004619.jpg
I will definitely be continuing on a new thread for my last part which will cover the marquee and its accessories!
End of part 2.
