[NEW VERSION] New STV Multi Dark Knight Edition !
can you please run the hardware test, the advanced one that checks also for the communication and status of the 2nd SH2 and let us know what it says?
Looks like it can't see the multi cart.
this one? which test to run? here are 3 i see that failed
Yes, this one. I think that you want to check specially the dual CPU one. What does it say?
that is good, but doesn't mean that the soldering is OK. It looks apparently like your mobo can't see the cartridge.
Maybe a stupid question, but does the console go to a blank screen reset during the game writing process and then reset?
do you hear the music playing when the game has been written?
yes I hear a Chime when it starts and it resets itself after the install
just double checked. yes the screen goes blank. with the files I have it says sega when the flashing starts and sega when it completed. but the error persist
One thing to check is the chip that you connected the reset wire to. Make sure that the soldering is still good on all the legs. Use a multimeter to beep it out and ensure to ensure nothing is bridged where it shouldn’t be. I vaguely have a memory of this being an issue when I installed a multi a while’s back but can’t remember the symptoms.
just checked. all is good. not bridges and I get continuity all the way to the other chip.
I’m away from my arcade stuff at the moment otherwise I’d help more.
If you could test the multi on another motherboard that would help.
Ok. That rules out the mobo imo.
Did you try with a different microsd? Which one are you using?
If the same happens with a different one, let us know and you can send to us and we'll have a look. Either we fix or replace.
I actually just ordered some more micro sd cards from amazon to test in the morning. I ordered some sandisk 16gn cards
The smaller the better. If you have some old 4gb those should work well. Remember that only SDHC cards are supported, not SDXC.
The 16gb card worked and I'm off to the races!! turns out it wasn't the sd card, it was my mac formatting. I just happened to read another thread that said don't use a mac to format the card. Thank you to everyone who chimed in to help me out!
Hey there y'all, recently picked up an STV multi and installed it today. Unfortunately most of the games I've tried loading up just say "Error on cartridge" and won't boot. Have been able to get Radiant Silvergun and Guardian Force to run. Have read that the issue could be the SHC2 IC's, did go into the system test and they show as ok.
Currently am using a Sandisk 16GB microSD card that I formatted to FAT32 and the game pack is the Darksoft 2023 version. Using an original JP bios. Soldered on the reset wire and audio wire. Board currently does not have a 2032 battery installed but thought that would just mean it couldn't save settings/high scores. Is there anything else I should check before seeing about reflowing the SHC2 IC's? I feel like I'm alright at soldering but haven't done much surface mount work and don't have a hot air station.
Tried using another Sandisk 16GB card that has worked fine in the Darksoft Taito F3 multigame, still the same issue. Also confirmed that Cotton Boomerang and Cotton 2 will load.
