Open Source USB2DB15 for Supergun adapter
You can now pre-order your USB2DB15 on our ko-fi website!
https://ko-fi.com/s/b6c3d01043
USB2DB15 Firmware and PCB update.
[0.14.14] - 2022-05-14
---Added
- Added Support for PowerA FUSION Wired FightPad Gaming Controller for PlayStation 4
- Added Support for FeralAI Pico Fighting Board GP2040 (PS3/DirectInput Mode)
Amazing work, thank you @Raph_friend your hard work and focus on making this project awesome is hugely appreciated! Also loving that CPS2 product placement in the background - truly the king of arcade hardware
Can I use the screw holes on either side of the DB15 connector to screw the adapter to my Minigun to keep it from sagging? What thread and length screws should I get? Thanks!
The version you got don't have metal plate on the DB15, right?
The initial batch's i didn't realize that was possible to use glue on the plate, so i sent without, you can get any Db15 connector and remove the plate so you can use put on your USB2DB15. On the supergun DB15 you bent a bit on the middle top and bottom, it may help on your saggy issue.
If you find any other way please post here or use the support channel on discord.
USB2DB15 Firmware and Library update.
[0.14.15] - 2022-05-26
Changed
- Fixed an issue with button mapping surrounding Mad Catz Street Fighter V Arcade FightStick TE2+ (PS4 Mode) controller.
Added
- Added Support for Logitech F310 (thanks @narf )
- Library updated: https://github.com/Raphfriend/USB_Host_Shield_2.0
- USB Host Shield 2.0 files updated:
- hidescriptorparser.cpp
- hidescriptorparser.h
- Usb.cpp
hi,
I would like to try to realize my USB2DB15.
I can't found easyly
IC1S-816A40AMC-BAPT2USOT-23-5Linear Regulator Positive 5V 1A 5-Pin SOT-23 T/R - Tape and Reel
do you think I can use:
€ 0,78 Réduction de 6% | Lot de 20 pièces LM321 LM321MFX A63A sot-23-5
https://a.aliexpress.com/_vWUMgf
or do you have link?
Regards
hi,
Regards
Answered on discord.
Does anyone have the parts list or a Digikey cart for this project? Seems the there might be some formatting errors with the CSV file retrieved from GitHub.
Can you please tell the errors?
Since it is saved as a CSV file, the line for C2, C3, C4 is displayed incorrectly. I am correcting it now.
I am also finding discrepancies for these parts:
  1. DB15OUT
    • You have it listed as "DB15M/90"
    • But since this is going to mate with a SuperGun, which has a male DB15 plug, I feel this should be "DB15F/90"
    • Please confirm if this part number works for this component
  2. LED
  3. C1
    • Please confirm if this part works for this component
  4. C2-C3-C4
    • Please confirm if this part works for these components
  5. R2
  6. R3
  1. DB15OUT
  2. LED
  3. C1
  4. C2-C3-C4
  5. R2
  6. R3
1. It looks good. We only care about the position of the holes on the PCB because everyone (or 99%) who uses superguns is aware of the female/male sides. But it's a good point, and I'll add it to the BOM.
2. Looks fine.
3-6. All of these parts are generic; use whatever works best for you.
Thank you for double-checking.
@Raph_friend, can you please post the gerber file? When I convert the *.brd file in EasyEDA, the silkscreen is lost and for some reason I can't reset my Eagle password.
