Sanwa 29e31s - add VGA connector?
reclaimer
Bay Area, California, USA
EDIT- it’s a 29e31s monitor and I need to get VGA/Power/degauss connected to a blast.
Hi all! I opened one of my brand new Sanwa PFX monitors, and surprisingly it doesn’t have the VGA connector.
I had heard mention that some of the chassis didn’t have one standard? So strange.
Any ideas of how to get one wired up?
(I’m putting this in an old empty Blast City shell. Yes I know I need to modify the bezel :)
DD4FEF84-89A4-465C-9DFC-ADA6B2890FF3.jpeg68EA92ED-FE5B-4C0C-809E-78DD1D236F2E.jpeg0D404B3A-B013-4B2C-9CCA-3C3376FFD261.jpeg8BD74120-BEAF-4317-84DC-9AB1A162D132.jpeg4A291351-FBC0-4C4F-AD50-99577344DE0A.jpeg
If you have a standard blast harness, you will have to rewire that sanwa connector to the RGB/S/G/AC/Degauss Lines used by the blast city, (And Astros) It's a 15 Pin TE Universal Power AMP connector.
Instead of the connector you have there in the pictures you wire it up with this connector:
https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/176300-1/1153001
I'm not sure about the VGA line on that chassis. That seems more complicated to wire up.
HUH!!!! wow I dont think.... hold on let me check something
ok so that looks like the 29e31s vga chassis there should be two headers that a vga port gets connected to 2 seperate pin headers I can send you one let me get some pics
yeah I dont see that header where the rgb is connected in his pics
You know what its probably the 29pf31 that came in those US tekken cabs
You know what? I was kind of afraid to mention it!
and some 29e31 have the vga plug btw...
is the model writen on it? like this:
and this sure looks like your picture ! !
Yup... sorry but you have a 31hz only monitor!
Hi all! I opened **one of my** brand new Sanwa PFX monitors, and surprisingly it doesn’t have the VGA connector.
Wish I could flex like that :) :) :thumbup:
You may want to look into the A1 scaler, originally designed because my cab was 31K only..
I’m fine with a 31khz only monitor, I can totally use scalers if I wanted to… I just want VGA hooked up to this fucker. 😂
I pulled it out of a stack of boxes that all had standard PFX monitors I’ve been using in other cabs, and it had the same box… so I didn’t even look at the models on the chassis or tube. Lemme get in there and take a look later.
S
Stack of boxes!? I'll be in San Jose again if you have any extras 😁
Sanwa schematics are not always the most clear…
Hoping these helps and hey, if you want the connector and wire, send me a pm and i’ll mail it out… its a spare i have and was unfortunately cut on the other side…
