Shienryu System Assignments?
Brentradio
Las Vegas
For some reason I can't get Shienryu to load.
Not available with system assignments.
I have the system assignments set to 2p and Vert.
Now what?
Thanks,
Brent
What's happening? It's successfully programmed, you get to patent notice screen? And after that it's a black screen?
Power off, press and hold the test button, it will bring up a 'hidden' test menu. Select the option to test the slave cpu and check the result.
Here's a pic of what it says.
This pic says SeaBass Fishing but it does the same thing on Shienryu...
Try 1p vert. Seems to be a 2p game but it might work. As far as I know JAMMA boards don't have a way to check for coin mechs like JVS does.
Man if I hadn't left all of my ST-V stuff back in NC I would verify this stuff for you.
Ok, checked everything out in that menu, everything seems fine including the slave cpu.
