Do you think a 10 uF, 25?v would work instead at this spot? I don’t have one available.These are the values - you just have to get the right footprint:
C135 is marked with "C106" so 10 uF, 16v.
L1 is marked with "470" so 47 uH
Thx bro.Yep - you can use a higher voltage cap, although it might be physically larger - just check the placement.
I am an idiot and have never understood how to order properly sized capacitors from Digikey. I tried to order these replacement parts but they were waaaaaaay too small. Can you guys give some advice on which size to get please, & thank you.
