FrizzleFried
Does the Chihiro system use a separate battery or NVRAM to store settings/high scores from the battery that is used in the netbooting/memory retention system?
I ask because as most of you know, I have an Outrun 2 that I netbook Outrun 2 Special Tours... I also have setup a power supply/UPS system that replaced the usual battery for the netbooting system...
Oddly... while my actual data (the Outrun 2 Special Tours code/data) is retained lately... my actual SETTINGS and HIGH SCORES are being lost if I power the machine down for more than a couple hours.
Based on this fact, I can only assume there is some other battery in the system for settings/high score retention? If so, where do I look and what type of battery am I looking at?
EDIT: Now that I am thinking about it. I seem to recall a coin battery on the main board... I'm guessing that little bugger has gone bad on me.
