Streetfighter 2 repair...
PLA? if you are copying GAL's I assume you mean PLD, when you dumped it did it come up as blank/all FFs or something i.e protected?
there is a heap archived here
https://wiki.pldarchive.co.uk/index.php?title=Street_Fighter_2_(bootlegs)
none are referred to as U6 though. We can also thank Hammy for alot of them.
Yes sorry I meant PLD I've got 3D printing PLA on the brain!
Yes Hammy's helping me out with a U6 but basically I'm able to read a U6 PLD and verify it. I'm also able to burn a GAL and also verify it with the original U6 PLD but when I pop it in the board it doesn't work. Pop the original back and that does work so I don't know what's happening there.
Finally got some pics, I've got two of these boards with the 4 roms direct on the board by the 68000
The never ending repair thread!!!
Every now again this board comes down from the shelf for further investigation and repair attempts. I've since had success with other boards but this PCB is my Nemesis!
After watching a repair video of Hammy's stating that the mask ROMS where 27C800's split in two with the same data in each half I de-soldered one of the graphics mask ROMs and attempted to read it. After I split the contents 2 x 512k banks into 4 x 256k banks and ran them through Romident it recognised them as Street Fighter 2 RK bootleg version.
I changed the sub-board ROM socket a while back into a turn pin so I could still keep trying the 4 x ROM sub board but also throw a 27c800 in the socket. I noticed a board for sale on Worthpoint a while back and someone else earlier linked to this image which is my board with a single main CPU ROM! (see pics last one is mine).
Anyway I've put the main CPU ROMs from the RK version on a 27C800 and I'm getting address and data line activity again and occasionally music but I'm not sure I've burned them in the correct order it's a bit of a faff with an adapter and bank switching.
Anyway and this is the real kicker!!! Before all this when I was checking other stuff on the board I slipped with the logic probe and shorted a 74LS157's under the graphics prom chip. The screen went blank and hasn't come back since so I'm working blind at the moment. No Sync at the edge connector and no activity on RGB lines. I've checked the 16hz crystal and that's good and I can pick it up on pins 1 and 2 of of PLD U151 but from there no further. I traced the sync line back from the edge connector to pin 21 of U131 but it has no activity at all at that point.
Any tips to get some graphic output back gratefully received...
I'm assuming probably incorrectly that the row of PLDs running horizontally through the board U151, U125, U96, U95 are graphics related and I may have wiped one of those out?
At this point it's been put back on the shelf. 😂
Pin 15 is often connected to ground. If you shorted it to pin 16 you probably vaporized a small trace. Kynar is your friend.
Yes a definite whiff of burnt trace filled the air. It's typically underneath an IC as well from what I can see!
Finally this board is up and running. A good learning exercise so thanks to all who contributed and a special mention to Hammy who's patience I truly tried!
So as mentioned slipping whilst testing I ended up burning some PALs: U104, U135 and U151. It turns out U151 is clock dividing 16mhz down to 4mhz and suppling this x 4 to the graphics PLCC.
The fried trace which I whiffed burning when I shorting the pins but couldn't find was coming out from under the U68 sprite ROM and going to PAL U107 and logic ic U1
The ROM set is the L735 test ROM although the board could probably run others but lets not run before we can walk!
I still have horizontal lines through sprites and some vertical lines but hopefully that's just a simple RAM swap.
Sure this board is a bootleg and many would question working on it but this exercise was only ever about learning some stuff about arcade boards on a budget and since starting this board I've repaired others and learned a lot.
The soldering skills are now night and day also now which helps.
Maybe this thread will help someone else?
